Question about Toshiba 42H81 42" Rear Projection Television
All Dots, no clear picture
I have had this TV from Sept 2002. But this problem has got me stumped. When I turn on the TV, I have all the colors (red, blue, green, etc) in dots, but no clear picture. Sounds and all the effects are there (color shading, etc) It seems that the picture is scramble? Any thoughts???
    Scholar:
  • 150 Answers
Might be the Flex Converter Module, They have issues at about this age. I think there are some bad caps in the module, dont know for sure always sent in for rebuild. If you dont know alot about these, these toshibas are a pain to pull apart and back together working, you might want a professional to do the work.
Posted on Jul 06, 2007
How do I fix my LG 50PCd5 Plasma TV?
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 11, 2017 | LG Televison & Video
I have a panasonic color tv. Model # CT-27L8SG, sept 2003. Recently , when I turn it in it says Video 1 but not sound or picture.
Do you have anything plugged into your video 1 input? If so, is there a signal reaching your set's input? Try other inputs and see what happens.
Mar 05, 2017 | Panasonic Televison & Video
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
Can i realine the lens myself it has a yellow tint and yhe lettering is out of focus
If you have yellow coloring on everything, this is not a lens alignment problem. Either you have a color balance problem (weak blue) or the coolant fluid in one or more CRTs is going bad. The coolant liquid is supposed be clear, but with age it breaks down and turns yellow.
First, unplug the set and remove the back. Use a mirror if you have to, but look down at the top of each CRT using a bright light. They should be colored red, green or blue, with no yellow to muddy the color. That's a quick check on the coolant condition.
You can replace the coolant, but be very careful not to spill any inside the set. Broken-down coolant can short out electronics and cause a lot of damage to the circuitry, especially in the high-voltage sections. Some people prefer to remove the CRTs from the set for this process, but that is a considerable amount of work. Others use kits with pumps to remove the coolant, and work inside the set with reasonable precautions - if there is enough room. There are a number of good tutorials on-line, or at least there were when I last looked two years ago.
I recommend getting the color right before attempting the focus. Bad coolant may scatter the light and fuzz up the picture, so check that out first and post back what you find.
If you have yellow fringes on otherwise normal colored objects, the blue convergence is off. This will also make lettering appear out of focus. Most RPTVs have a procedure for bringing up a convergence pattern (a grid of dots) using the remote control. The dots should all be white or have very little color fringing. Follow the directions, and make small adjustments, then check the effects all around the picture. Correcting one section may cause a change elsewhere. Use a ruler to make sure the dots stay in the right place; otherwise you may end up with a distorted picture.
Caution to other readers: do not try to adjust convergence if you have a "bow-tie" shaped picture in one or more colors. This indicates a convergence amplifier failure, which must be fixed first.
Oct 12, 2010 | Samsung HCN5527W 55" Rear Projection...
Samsung LCD Flatscreen only shows lines of color or purple dots
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
We purchase a Hitachi TV #42V515 Sept 2005. We
Go to the place you bought it from and ask them, to me it sounds like your color wheel is going.
Nov 20, 2009 | Hitachi Televison & Video
Zenith Plasma
My TV has a picture but its very poor quality and its fading ,blurry color it is not clear what can i do to fix.Thanks
Jul 21, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Sep 10, 2007 | Sansui TVM1916 19" TV
Toshiba 42H81 42" Rear Projection Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
