Question about HP DesignJet 2500cp InkJet Printer
2500cp-check printhead path error - HP DesignJet 2500cp InkJet Printer
smt24
  • 54 Answers
SOURCE: Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Posted on Jun 05, 2009
Preeth Tom
  • 129 Answers
SOURCE: check printhead path error message
hi
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Posted on Sep 10, 2009
deababrata
  • 66 Answers
SOURCE: HP5500 Error reads as follows:
first you open the cover and then switch off the printer and after  15 minuits tou on it and it works.
Posted on Oct 23, 2009
Testimonial: "Thanks I'll give it a go"
  • 75 Answers
SOURCE: Switch Printer off,check printhead type path (2).
it seems like there is no oil on the slide bar
Posted on Mar 15, 2010
  • 123 Answers
Check for free carriage motion by unplugging the printer while the carriage is in the print area of the plotter. Open the top cover and move the carriage to check for free movement. If there are rubber crumbs under the belt, the belt is worn out and needs to be replaced. Manual can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Parts available at: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Posted on Apr 15, 2010
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Check print path error after belt replacement (HP 1055)
Did u observed the belt having 50% vertical tracks & 50% horizontal tracks?. The vertical tracks as well as horizontal proper position?.. understand the snap., re install the belt once again as shown in fig... i hope UR problem will be resoled..
Apr 15, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Designjet 2500cp error 010036 00000100
This can be caused by a faulty electronics module, trailing cables, printhead carriage assembly, or ANY of the stepper motors.
try this...
Switch the printer off from the back, and then disconnect the trailing cables from the electronics module.
Switch the printer back on.
If the error code changes to '010037'
If the error stays as 010036, change the Electronics Module.
If it is 010037, replace the trailing cables, then the carriage assembly.
Trailing Cable Part No. C4704-60015
Electronics module Part No. C4723-60114
Apr 29, 2010 | HP DesignJet 2500cp InkJet Printer
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
Error message on brother dcp 540cn 'unable to change 30' have swithched it off and checked all cables. No joy It sometimes changes to unable to change 50 help appreciated!
This is almost always associated with debris or foreign objects in the printhead path or under where the printhead "parks."
With the power off, open the cover. Inspect the printhead path for little bits of paper, push pins, paperclips etc. Note the position of the printhead.
If the printhead is at the far left, gently slide it towards the center. Carefully look under where the head was positioned for debris. Use a flashlight if necessary.
Close cover. Plug in the machine. Try it again.
Jan 05, 2010 | Office Equipment & Supplies
Check printhead path error message
hi
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
Printer head contact error.
no. sorry Rick but i think you really need to replace the carriage assembly, if you can find one. these printers are aged. hope this helped you.
Apr 26, 2009 | HP DesignJet 2500cp InkJet Printer
HP DesignJet 2500cp InkJet Printer Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
