Question about Activision Cabelas Dangerous Hunts 2013 - Xbox 360
Fear master gun not responding to sensor
My FearMaster gun is not responding to the sensor. Gun turns on. "new" batteries in all devices. But is still not responding .
  • 21 Answers
SOURCE: can not get the360 xbox console to recognize that
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Posted on Jan 08, 2011
  • 21 Answers
SOURCE: my gun doesnt work
Posted on Dec 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: I got the Cabala's Dangerous
What game system is this game for?
Thanks!
Posted on Jan 02, 2011
  • 21 Answers
SOURCE: Problem with the Activision Cabela's Dangerous
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
ladysrome
  • 54 Answers
SOURCE: gun won't sync on 2013 cabelas dangerous hunts
Good game equipment can help you solve this problem, a good gun model controller can let you enjoy a live-action version
Posted on Dec 07, 2012
Paslode 350i first fix nail gun. Charge both batteries (1 is brand new). Put battery into gun and fire. Im lucky to get one nail from it before gun shows up red.
Sounds like either the battery is bad, or since one is new its possible the contacts in the gun are not making proper contact. Are you sure your charger is working as well ? If you have a volt meter check that the battery does have a charge on it.
Oct 10, 2016 | Air Tools & Compressors
Bostitch just blows air when trigger is pulled
Air leaking from trigger when attempting to fire the gun is normal and should cause nailer to fire, however if the trigger pin is not depressed all the way in,the gun may not respond. Easy test. Remove the nails and remove the trigger. Connect the gun to air and quickly depress the valve pin all the way in with finger. If the gun fires, adjust the safety foot so that the trigger pin is depressed all the way in. If the gun still does not fire, then remove the head cap and pull out the headvalve. Apply plenty of white grease to orings and retest. If the gun fires, then replace the headvalve orings. When the headvalve orings are worn, air will leak from bulkhead chamber to the headvalve chamber causing the gun to not respond to the trigger. The addition of grease to worn orings will make them temporarily seal. Good luck
Jun 16, 2016 | Stanley Bostitch N66c1 114"to 212" Coil...
There is no light coming on with a battery connected
First what kind of gun? If Paslode- may need new gas cartridge. And is power light green (still paslode gun.) If other type of gun can't help. sorry.
Feb 17, 2013 | Air Tools & Compressors
Gun won't sync on 2013 cabelas dangerous hunts
Dec 06, 2012 | Activision Cabela's Dangerous Hunts 2011...
For the Cabela's gun what is the sensor bar and the sleep timer swith for?
The sensor bar receives the signals from the gun when you use it for a shooter game (for example: Cabela's dangerous hunts 2011). You stick it right under or on top of your tv, turn it on, and set the sleep switch on it so that it won't just drain the batteries in it all day long.
Jan 06, 2011 | Video Game Consoles & Games
My son received the Top Shot Elite package from his Grand parents for Christmas. We do not live very close to Cabela's to return the defective gun, so hopefully you can help. The gun is brand new and it...
ee the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://la-va.facebook.com/topic.php?uid=133041143393695&topic=331
Jan 02, 2011 | Activision Cabela's Dangerous Hunts 2011
I cannot get the top shot elite to connect with the PS3
1. Turn off the PS3 system.
2. Make sure the gun and the sensor bar both have batteries in them, and the sensor bar is placed either above or below the TV.
3. Remove the USB connector from the end of the stock.
4. Turn on the sensor bar.
5. Connect the USB connector to the PS3 system.
6. Turn on the PS3 system.
7. Press the PS3 button on the gun.
8. Press the Connect button on the end of the USB connector.
9. Press the PS3 button on the Gun again.
10. Gun must be pointed at the sensor bar to pick it up.
This should fix your problem. Merry Christmas!!!!
Dec 25, 2010 | Activision Cabela's Dangerous Hunts 2011...
Activision Cabelas Dangerous Hunts 2013 - Xbox 360 Logo
786 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
