Question about Williams Heating & Cooling
My charmglow patio heater (model SRPH-02) lights but goes out after about 5 minutes of operation. Don't know if this is something I can fix or do I have to have it serviced--who even services pat
Also takes several attempts before pilot lights.
hotuna
  • 288 Answers
SOURCE: windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Posted on Mar 06, 2008
AZSTALZ
SOURCE: charmglow patio heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Posted on Nov 09, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: model SRPH02 BURNER WILL NOT FIRE
Bad flame sensor. Try to clean it with some steel wool
Posted on Apr 24, 2009
co7196
  • 3433 Answers
SOURCE: Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Posted on Jun 10, 2009
SOURCE: charmglow gas patio heater
charmglow heater,,my pilot lights,but when we turn knob to #2 the pilot goes out.tank is full,is it the regulator or the thermostat control valve?
Posted on Jan 10, 2010
I have a Charmglow patio heater. I have taken it apart and cleaned all openings where the gas comes out, but the flame still goes out after 7-8 minutes. It lights fine but will not stay lit for more than...
From what you have described, it sounds like the Thermocouple is going bad and needs to be replaced. As far as not being able to relight the pilot right away is concerned ... that's a safety feature. The control has to reset itself, before you can relight it, if the pilot goes out on it's on. As it did in your care. It usually takes about 2 - 3 minutes for the control valve to reset itself.
As far as replacing the Thermocouple is concerned, it's somewhat of a specialty item, because of it being in a tall patio heater. However, armed with the Model # of your Charmglow Patio Heater, you can probably purchase one from the manufacturer, Chamglow.
Hope this helps.
Feb 14, 2011 | Heating & Cooling
Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
May 16, 2010 | Brinkmann Charmglow 810-7400-S Propane...
CHARMGLOW PATIO HEATER WON'T STAY ON
Probably a venting problem! Can be very difficult to diagnose and repair'
Mar 09, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Patio heater keeps shutting off
Returned it to Home Depot, paid $50 for upgrade to "better" unit.
Sep 28, 2008 | Coleman (5040B750) Patio Heater
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Charmglow gas patio heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Coleman patio heater 5040A770
These heaters are not designed to be operated below 40 degrees F. If the heater is used below 40 and if you have a gas tank containing less than 25%, the unit will not operate for long and will start going out. If the heater all of a sudden goes out without showing any flickering or pulsations, you have a bad gas valve, there is no thermocouple on this model. Fill your tank and try the heater again. If it continues, give Coleman a call at 800-835-3278.
Nov 15, 2007 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
85 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
