Question about Exercise & Fitness
My horizon quantum hrc belt is slipping when you run help
4 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: after 10 seconds running my horizon fitness
The E1 error code is the reed switch signal is not making it to the motor controler. Or that the controler is bad.
Unplug the treadmill and hook it back up, remove the motor hood and check the motor controler for a red light, it should remian lit without flashing, showing the unit has power. When you press the speed buttons, the light should start flashing, then the drive motor should start driving the walk belt. Watch the red light to see if it stops flashing when the belt stops. It should. Does the treadmill read speed and distance before it quits? If so, it most likley is a heavy draw on the drive motor causing too much restistance, which shuts the controler down.
Hope this helps.
Matt
Posted on Dec 10, 2010
ercupa190
  • 12223 Answers
SOURCE: I recently purchased a Horizon Quantum HRC 2
If the Drive Belt is Not Moving :
Watch this video:
http://www.youtube.com/watch?v=GdlAxZHLDys&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
You should not adjustthese since they are preset. Tension can be affectedslightly by adjusting the tension of the walking belt but if you have a slippingproblem, the drive belt will require replacement. If yourdrive belt is too loose, it will slip on the front roller pulley or the motorpulley. If it is too tight, it will increase your amp draw to the point thatyou may have an electronics or motor problem. Due to this, it is better to beon the safe side and replace a drive belt rather than riskover tightening it. A drive belt is usually $29.99 or less while many parts youcan damage by over tightening can be more than $300.Additionally, too much tension can cause bearing failure in the motor and thefront roller and front roller pulley failure. It is better to err onhaving the belt a little too tight rather than too loose due to the possibilityof injury if the belt slips. Motor Belt Adjustment-Icon Units Do not remove any of themounting bolts to the motorthese repairs will require 2 9/16" wrenches andmayrequire two people to accomplish the repairs Before beginning this repair: Check to make certain that the drive belt requiresadjustment. Check out belt slipping instructions or with the motor cover removed,walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If theproblem is in the drive belt, eitherthe drive belt will stop when stalled or the front roller will stop whenstalled. If the motor, drive belt, and front roller continue to turn when thewalking belt is stalled, the problem is with the walking belt slipping on thefront roller. If the drive belt continues to turn but the frontroller stalls, you may have a broken front roller pulley.If You need further assistance, please reach me, sincerely. G-d Bless you.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Posted on Oct 29, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 16, 2012
I cannot adjust or reset the speed on the console as it just goes straight onto the fastest speed every time I start it up and even if you adjust the speed and/or the programme it still starts in the
Hey Tyler,
You may need to re-calibrate your treadmill you can check out this video http://www.youtube.com/watch?v=MWDvxTKXem0 it will guide you through it.
if the problem reoccurs after the calibration then you may need to replace the speed sensor... it is usually located next to the drive motor pulley (it is a magnetic pulse speed senor so it should be facing the magnet on the motor pulley) P.S. if the sensor is not lined up this can be the cause of the problem also, so check that it is before replacing.
Hope this help... Enjoy
Apr 17, 2014 | Horizon Fitness Exercise & Fitness
I have a horizon fitness omega 3 hrc entertainment treadmill it has a Jm05-002 h.p 1.75 hp motor. I'm looking to know what is wrong with my treadmill when I press it on to start some times the...
d8059ac5-911d-453b-a576-434df5747959.gifplease see the video and lube+rollers bearing front and back, test the drive belt motor, and replace the belt if necessary.
However if the problem persist, your control board is faulty.see the block diagram
Jul 21, 2013 | Exercise & Fitness
I have a Quantum II HRC treadmill, it worked for a short period and stopped now I can't get the walk belt to work.
LUBE the deck belt, you have a WORN deck belt, by lack of maintenance schedule.
2) LUBE the rollers bearing too
3) Test the drive belt motor, for worn, cracking or adjust it
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 19, 2012 | Horizon Fitness Exercise & Fitness
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
I recently purchased a Horizon Quantum HRC 2 treadmill which was working fine at the sellers house. I transported it home, started it up and it worked for a few seconds, I stopped it and then the belt...
Watch this video:
E.CUADRA
Oct 28, 2011 | Exercise & Fitness
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
My treadmill slips a bit whilst running on it everytime, how can i fix this?
Thank you for your question! Let me walk you through a process to determine what is slipping on your treadmill. Follow the directions below and this will diagnose what is wrong. If you need parts you can obtain most horizon parts cheaper on ebay and if you do not want to use ebay go through the factory to order them.
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Aug 25, 2010 | Horizon AFG 3.0 AT Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
