Question about Coffee Makers & Espresso Machines
Unable to remove swing out brew basket on BVMC-EVX series 12 cup Mr Coffee Programmable coffee maker
Manuel says to wash carafe and brew basket before use. There are no instructions on how to remove the basket so it can be washed and I don't see any way to do it.
SOURCE: instruction manual
Go to http://sumanual.com maybe there you find the instructions.
Posted on Apr 22, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
  • 85 Answers
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
The coffee is not hot. I have PSTX series.
Does the bottom surface that the carafe sits on get hot. Too hot to touch? If not there may be a wiring problem. If it is a new machine, I would return it for another. Hope this helps.
Dec 25, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
How to clean the coffee maker?
The easiest way is to run a cup of white vinegar in half a carafe of water through the brew cycle, followed by at least one carafe of clean water.
Jul 16, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Just purchased a PSTX series coffee maker. It is really fast and has the SS carafe. My question is, does it have a warmer or does it just rely on the SS to keep the coffee warm?
No in the BVMC-PSTX90 or 95 series.
If this is your model, Is a good coffee maker.
If you are NOT drinking your fresh brewed coffee withing 25 min. YOU DON'T WANT a warmer/burner.
And the reason why, IT BURNS the coffee. You don't have this problem with the "thermal Carafe".
Jan 11, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
