Question about KitchenAid 24 in. KUDP01FL Built-in Dishwasher
Model KUDS30FXSSO, Unit attempts to start. Blue light on the front of the door comes on indicating the cycle is starting. Pump runs a few seconds as normal. Then the maching sounds like it trying to start the next step three or four times. The blue light goes out. The washing cycle then switches to cancel/drain, ( I opened the door to see which control lights were on.) runs the drain pump then stops. The green light on the front panel does not come on indicating the cycle was completed.
catriver
  • 878 Answers
SOURCE: cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Posted on Oct 15, 2006
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
  • 423 Answers
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
Posted on Apr 11, 2009
  • 12 Answers
The problem is the control panel. You may have to shut the power off for a few seconds to reset the control board, then check to see if it works. If not, the control board has a break in the wiring or the keypad is no good.
Posted on May 13, 2009
heatman101
  • 43501 Answers
SOURCE: water not draining after wash cycle. Pressed
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 15, 2010
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin. clothes soaking wet,spin cycle shuts off at 7 mins
is your door lock light lighting up? if not you have a bad board and wax motor in the door lock. if you look at the board and locate r11 and see it burned this is 100 percent your problem. now do you have delay wash cycle? if so set it into delay and then locate your motor control board which is in the bottom you need to oipen the door and remove all four screws. be carefull the door may fall off don't remove the door but do remove the outer piece to locate the motor controller. Locate the jp4 connecter and remove it. make sure the unit is unplugged when openning up and removeing these. Now plug unit in if the unit starts tumbling, you may have to hit start, but if the unit continuously tumbles then you know that your motor and your motor controller are ok. If they do not then you have a bad motor/motor controller. Now if it tumbles freely you have 3 out of balance sensers one of them is bad they have 2 blue wires going to them check the connections and make sure non of them are broken and let me know how it goes
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Duct fan comes in, igniter lights, but no flame
Remove the front panel. Tape the door switch to the closed position. If the thermostat is calling for heat the furnace should do the following: a light on the circuit board will flash and then the exhaust blower will start. A few seconds later (10-15) you should hear clicking at at the circuit board and an orange glow should be seen thru the small viewing port. A few seconds later the gas valve should open and the orange light will turn blue. If the blue flame only lasts a few seconds and then goes out, their may either be a blockage not allowing the flame to travel to all the burners and not allowing a flame sensor to sence flame, shutting down the unit. After a few cycles of not starting, the circuit board will flash a series of codes that you can read if you look on the back of the front cover. It will give you a starting point where we can research and come up witha more difinitive answer. Let us know what you find for codes.
Oct 26, 2007 | Goodman GMS90703BXA Heater
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
KitchenAid 24 in. KUDP01FL Built-in Dishwasher Logo
66 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
