Question about RCA P60921 60" Rear Projection Television
No power with remote or manual power switch
Step i took replace blown 5amp 125v main fuse,tv power on but have bow at the top and bottom of screen,the picture image and quality of color is poor. image on screen is 2 dimentonal and red in color. took your advise and took set to a tv repair shop tech stated the convergence power supply board need replacing and this may not solve the problem!would cost 600.00 to replace the convergence supply board. caught in the middle i not sure paying 600.00 to replace the supply board and it may not solve the problem is fiscalable.need second opinion.
Replace the Sanyo I.C. Chip on the convergence power supply board. Cost you about $5.00. You are getting stiffed for $600. It is not necessary to replace the whole board. Fact is they just repair/recycle the boards anyway. It's a racket. Any good TV Technician should do it for $100 and still make a killing. You can buy the part here.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Posted on Oct 13, 2007
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Posted on Jun 29, 2007
The television quit working during a storm and seemed to not be getting power. Took off the back and found the 5amp/125v fuse blown. Replaced it and it blew again as soon as I plugged it in
Hello
All telivisions are provided with fuses, and the function of fuse is to protect its internal circuit agains short circuit, and protect the other components in the TV. if fuse must blow, surely there must ba reason. Without rectify that reason, if you put the fuse and switch it again, it may poise to other more problems. So get it repaired with a qulaified service personal. Never put any more fuse in it and swich on the Tv. Ok.
Oct 18, 2010 | RCA Televison & Video
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Wont come on house was struck by lightning now everything comes on but the tv
Hi:
Open the television and follow the power cord to the main power supply board the fuse will be near this cords contact plug check for blown 5amp fuse, if fuse is not blown then power supply took a shock and needs repair.
Aug 18, 2010 | JVC AV-36D201 36" TV
Our TV picture is bowed inward and lettering is 3D. How do we fix this problem?
Go to Menu then to setup if you do not see Convergence in the menu then you have a blowed Fuse FL231 it will be on right hand side of FBT flyback Transfomer there is 3 in a roll it will be the Middle one they are small brown rectrangler Looking caps but are Fuses Located on the Deflection board Bottom Left hand Board.
Dec 24, 2009 | RCA Televison & Video
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
141 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
