Question about Refrigerators
Freezer keeps iceing up on older kenmore bottom freezer top fridg
If we let the freezer thaw good it works for a few months . fridge works fine also until the back of freezer ices up inside . The door seal appears to be good . I already blew the lint out from the condensor
  • 2,559 Answers
Hi,It is one of three things,
1:Defrost timer
2:Defrost element
3:Defrost thermostat
Please rate this solution
Posted on Jan 18, 2009
Kenmore fridge not cooling but bottom freezer is working fine
Do you see ice buildup on the back freezer wall?
Oct 18, 2012 | Kenmore Refrigerators
The fridge works but water keeps filling the bottom of the fridge. Is there a way to prevent this?
Guessing this is a top mount, freezer on top. Sounds like a defrost drain clogged. Pull off freezer cover and check for ice build up. If there is, drain is clogged, thaw and use compressed air if possible to clear drain
Aug 19, 2012 | Kenmore Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Top Freezer working, Bottom Fridg not.
ice block has formed in the air exchange from the freezer to fridge. Turn off and thaw out, afterwards, check to see if the fan motor is running unobstructed. If problem persists, replace fan motor with new
Aug 10, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
Water drainage in fridge
you can add a drain tube heater to it to keep it from freezing up, part number is SH250 universal drain tube heater..
Feb 10, 2008 | Refrigerators
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
