Question about E-Machines eMachines Desktop PC
Insalled new video card, computer locks up at start up,unable to
Unable to get past start up
  • machadojr_fe May 11, 2010
    check and make sure your motherboard supports the new card
    Genius:
  • 1,102 Answers
I would remove the card and put it back in
Posted on Jan 18, 2009
What is a card reader?
A card reader is a device that connects to your computer, usually via USB or FireWire. It then makes the memory card appear to the computer as an external hard drive. You can then copy files (including pictures and videos) to and from the computer as if it were any other hard drive. Using one is usually the best way to download pictures from a digital camera.
Feb 14, 2012 | Canon PowerShot A560 Digital Camera
My new t21 display said "unable to access card" my
If you are using the camera to download pictures to the computer you should be able to set around this problem by purchasing a card reader. These plug into the USB port and the camera SD card plugs into the reader, the computer then loos at the SD card as an external Hard Drive. Create a new folder in ? "My Documents" transfer the files from the camera memory card (copy past) into the new folder and you have your pictures not on the computer hard drive.
Do a "safely remove" "eject" or what ever language you computer uses to shut off the connection and disconnect the memory card from the reader.
Format the memory card in the camera always format the memory card after downloading pictures to the computer and always make sure it has completed the download and you have turned off the feed.
Failing this your do two things corrupt the card and possibly the camera software.
Okay another thing that the SD card have is a lock I'm giving you a diagram to see and make sure the card is in the write position.
Diagram
You should be good to go
Jan 20, 2011 | Canon EOS Rebel XSi Digital Camera
I am unable to format a Sandisk SDHC card on either the computer or the video Camera of which is a TCL Digital Camcorder 818 Full High Definition Video Capture. The card, and camera was only used one...
The problem is with the card, it may have been locked here is a diagram to show you the slide switch
Image here
Also each time you use the memory card it should be formatted, Format all new memory card to the camera it will be used in and each time you download the pictures to a computer format the memory card to provide a clean medium for additional picture files
Dec 28, 2010 | SanDisk 4 GB Standard SDHC Card with Rezo...
Unable to transfer Video files from Nikon S210 Memory card to Computer? How to get transfered.!
connect your camera usb cable to a pc after few moments open my computer and find a new drive [camera memory] like usb flash drive and select your video files , copy , past . Thanks.
Oct 03, 2009 | Nikon Coolpix S210 Digital Camera
Insalled new computer,cranks but wont start
Does it start and die after 1-2 seconds or just cranks and never fires? Did it run before you installed the computer or are you trying to cure a no start problem?
Jul 12, 2009 | 1999 Chevrolet S-10 Pickup
Unable to insall firewire card in my acer m3201
i checked out your computer on cnet.com, they say your computer uses pci express not regular pci. you may have the wrong card.
May 11, 2009 | Computers & Internet
Loud fan noise
hmm, it's very possible that the new fan is unable to spin fast enough to draw enough heat away fast enough. I'm guessing that this a separate video card and not the onboard video of the motherboard? and, is it the video card fan that is making all the noise?
Apr 01, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Cannot access the BIOS
welcome to fixya
when you first turn on the computer hold down F2 for a few secounds this should take you to bios screen and as for the new video card i hope you got a new power supply to no lower then 500w power supply with that video card if not bigger
i do not think the ps2 keyboard should be a problem....
hope this helps you out have a good day :)
Jul 31, 2008 | Biostar P4M800-M7A Motherboard
My computer restart wen insaling sp2 or antivirus and after fiew times i kant start windows it keep starting and restartig
That happened to my computer once, and all i could do was to use the restore cd, and it worked again.
Most probably there's damage to your system files, and if not that then it has something to do with your motherboard. Could be bad memory or a da maged motherboard.
Jan 05, 2008 | ASUS P5RD1-VM Motherboard
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
