Question about T-View TView (T606HR) 6" TFT/LCD Monitor w/Dual Mounting&Remote
CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
I BOUGHT THESE TVIEW MONITORS AND I WENT TO HOOK THEM UP AND THE ONLY PLUG IS S-VIDEO PLUG. THERE ARE NO OTHER WIRES ON THE MONITOR OR A PLACE FOR A PLUG. SO HOW DO I HOOK THESE UP? IS THERE A SPEICAL PLUG THAT IS NEED THAT IS S-VIDEO? I NEED HELP, THANKS
  • Tom Finger Jan 31, 2009
    My problem is quite similar to yours. I have the Tview T560HR 5.6" monitor. But it is NOT an S-video connection, as I ALSO thought. I got an adapter, and then realized it is not the same connector, when it would not plug in. From what I understand, it is a proprietary wiring connector. I was just going to check into the pin-outs myself, to see what I can figure, to do.
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Posted on May 15, 2009
What causes a Tview T244IR-BK not to power on when all fuses are good and where to buy replacement parts
That worries me when the fuses dont`t blow,otherwise I would have told you you made the wrong connections or did not ground enough. You can find fuses in any hardware stores and if your purchase is recent, have it replaced or get your money back. I suspect something wrong with the item. Or go to place where they are specialized in installing DVD monitors in cars; they`d tell you if it`s blown up or not. My TView monitor is really blown up and I am trying to find out if it can be fixed. My warranty has expired and I am kind of stucked.
Sylvain, Blainville, Canada
Aug 08, 2014 | Tview T244ir 24" Black TFT Wide Screen Car...
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
How do i bypass the safety ground to watch dvd without pulling the parking park??
This can be done, although may not be legal in some states. Look around on google. Just know that there is a reson the park kill feature is there in the first place.
Dec 23, 2010 | T-View TView (DVD170TV) Motorized 7"...
Need a power plug for 17" tview flip down monitor
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Aug 03, 2009 | T-View T1045IR 10.4 in. Car Monitor
Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Jun 10, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Car Audio & Video Logo
480 people viewed this question
Top T-View Car Audio & Video Experts
xxxxxx xxx
Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
