Question about Microsoft Xbox 360 Controller
Xbox 360 wireless contoller won't sync with game console
Our xbox 360 wireless controller will not sync with the game console. It won't even turn on. We've repalced the batteries, tried to turn it on, pushed the connect button on both the controller and the base and still no green light, no connection.
  • lynol01 Mar 06, 2009
    I'm having the same problem nothing will connect to my 360 controllers or even my wireless headset the controller still fails to work with the play & charge kit but everything works fine on my friends. this has enraged me and to make things worse I've just found out my xbox is two days out of warranty and will cost £68 to repair. so my advice is this try your controllers on another xbox and see if they work if they do you probably have the same problem as me so get in touch with xbox support and register for a repair before your warranty runs out
  • xiller8er
    xiller8er May 11, 2010
    Just checking, but make sure you're putting the batteries in correctly. and make sure the
    -How long have you had the controller? AND had it worked prior to?
    What happens when you hold down the center circle [X]box button?
    This is what you mean by "tried to turn it on.." Right? (just making sure...)
  • 3 Answers
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Posted on Feb 23, 2009
  • anarchybob6 Apr 08, 2011
    Dude u r amazing i just fixed a 360 that was given to me for free because it wouldnt even power on... it turned the power brick red but the brick would work on other 360's. i found that the problem was caused by one of the 16amp cylinder capacitors had popped idk y this happened. (i know so far irrelevant hopefully someone else has the same problem as me and that might have helped them. all i had to do is replace and resolder it) I know very little about 360's and i kept trying to sync the controller without it even being hooked to a tv. i looked all over the web for this answer and most ppl said to send it to microsoft but i have already voided warranty seal plus they were sending me in the wrong direction!!! (lols i would had to have payed microsoft to fix a problem this simple) all i had to do was hook it to the tv i cant believe it was that simple. U R AMAZING MAN AND THANK YOU SOOOOOOO MUCH FOR TAKING THE TIME TO POST SOMETHING THAT IS SO SIMPLE BUT CAN CAUSE SUCH A TERRIBLE HEADACHE!!!!!!!!
  • 3 Answers
Try pressing the small reset button at the front of your xbox then press the reset button at the back of your contoller hopefully your controller will then work again
Posted on Mar 25, 2010
I had this same problem. One day i was just playing my xbox and i noticed one of my good controllers was running low on battery so i switched the batterys and battery case out from each other. When i tried to reconnect the controllers after that they wouldnt work.I tried taping the batterys, buying new ones, unplugging everything and replugging, moving metal and wireless things, and cords and rechargeable batterys. I eventually called MS support using this number -(1800) 4MY-XBOX. At first a machine answered then i eventually got to a real person. You can ship your broken or not responding controller off and they will send you a new one. This worked fine for me.
Posted on Jun 30, 2009
  • RRoD666 Dec 19, 2010
    I had the same issue, too, after I fixed my xbox 360's red ring of Death issue. I was concerned I had messed something else up in the process, but it turned out all I needed to do was peform a wireless reset on the console (white button next to memory slots) and hit the connection reset buttons on the controllers. Voila!
    Problem Solver:
  • 5 Answers
My son had the same issue. I had him try to connect it to my Xbox. It connected fine. He has his on for hours every day. I had him turn it off and completely cool down about a 1/2 hour. We also installed the "intercooler" fan his uncle bought him which he never put on. Once cooled he tried it again and it connected just fine.
Posted on Jun 03, 2009
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
Feb 28, 2011 | Microsoft Xbox 360 Controller
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Feb 24, 2011 | Microsoft Xbox 360 Controller
Having trouble connecting xbox contoller
I assume you are having trouble connecting a wireless controller? Make sure you press the small sync button on the Xbox as well as the guide button on the controller. If this isn't the problem, please elaborate.
Apr 03, 2010 | Microsoft Xbox 360 Console
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
http://www.techsick.com/shop/images/P/xb360-controller-charger-36.jpg
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
Contoller wont conect to x box 360 and lights just flash with new batteries
Have you tried re-syncing the controller to the Xbox 360?
Press the small button right beside the expansion port located on the front of the controller. Then press the button located to the right of the memory expansion ports on the Xbox 360 console. This should re-sync your controller.
Hope this helps,
Bill
Sep 06, 2009 | Microsoft Xbox 360 Console
Need to sincrinize contoller with console
press the sync button on the xbox and then the controller
Jul 01, 2009 | Microsoft Wireless Controller for Xbox 360...
Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
Mar 01, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wireless controller not connecting.
it sounds like your controller keeps losing sync with the 360.
- turn them both off
- turn on the 360 with the power button on the console
- wait for it to start up, then press the sync button next to the usb flap on front.
- then press the sync button on the controller (by the recharge connection slot)
That should reset it.
Nov 13, 2008 | Microsoft Xbox 360 Wireless Controller
My wireless contoller wont connect
If so, it really sounds like your controller keeps losing sync with the 360.
Oct 16, 2008 | Microsoft Xbox 360 Wireless Controller
Microsoft Xbox 360 Controller Logo
10,208 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
marley mcelhinney
Pablo Gonzalez
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
