Question about Sanyo Split System Air Conditioner
SANYO SPLIT AC G AS LEAK TWICE IN 10 MONTHS
SANYO SPLIT AC SAP K 186 DEVELOPS GAS LEAK TWICE IN 10 MONTHS . SERVICE MAN SAYS I HAVE TO PAY AS I HAVE NOT PURCHASED FORM THE DEALER
4 Suggested Answers
  • 744 Answers
SOURCE: I have a split system SAP-K181AHA, SAP-K241AHA
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Posted on Jan 08, 2010
  • 88 Answers
SOURCE: I has a split AC there is problem of electrical
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Posted on Mar 27, 2010
  • 13 Answers
SOURCE: ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Posted on Jul 20, 2010
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
I wanna knw dat after how many months should split ac gas be topup? I also wanna knw dat what is d cost of split ac gas?
If the unit was charged correctly in the beginning and you have no leaks in the system - the refrigerant will reman good for the entire life of the AC and it's component parts. In other words, without a leak, the refrigerant will not wear out - or ever need replacing - and you will never need to add any.
Right now the average 'wholesale' cost of AC refrigerant (for residential units) is about $6 per pound.
Retail cost will vary depending on the service company providing the refrigerant - but you can figure somewhere around $12 - $15 per pound. The retail cost includes the tech putting it in for you and making sure the AC unit is correctly charged and that the reason for the need to add refrigerant has been fixed, i.e. a leak that had to be repaired.
hope this helps.
Aug 05, 2011 | Panasonic CW-1006FU Air Conditioner
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
Jul 20, 2010 | Sanyo Split System Air Conditioner
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
I has a split AC there is problem of electrical wiring between compressor and in house machine. I need some service center address in Ahmedabad city Gujarat to recify the same. My model No. is SAP-K184ML
Mar 26, 2010 | Sanyo Split System Air Conditioner
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Have purchased premises with a sanyo sap-k302ah split system air conditioner and the previous tenant cannot locate instruction book on how to operate can you help me out with one please Maxine
There you go
http://service.airwell.com.au/airwellsanyoparts/Website 2007 update/sanyo/SAP-C302AH/sm700568-00_11 service manual.pdf
If you cannot veiw please let me know and i will re post the link or email it to you
thanks for using fixya
Apr 22, 2009 | Heating & Cooling
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Sanyo  Split System Air Conditioner Logo
32 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
