Question about HP 48gx Calculator
Display / LCD issue
The my 8 yrs old HP-48GX calc seems to work fine but the display is very faint and is barely visible.
Is this repairable.
Try adjusting the brightness setting for the LCD screen by holding down the "on" key and pressing the "+" key at the same time to make your screen darker or the "-" key at the same time to make it darker.
Posted on May 01, 2009
Yes (although it can be a fair amount of work, and requires some skill). First, have you tried changing the contrast by pressing and holding "ON" while tapping the plus or minus keys?
Otherwise: There are sources that describe how to dissassemble the calculator (a challange in it self) and from there the display can be worked on. Usually what happens is that the glass display is connected to the rest of the circutry by "rubber" connections (actually, a rubber that alternates between conductive strips and insulative strips) and the clamping force that keeps the connections has weakened. You can test this by gently pressing down on the display and see if the contrast changes. If so, the clamping action needs to be strengthened, which might be possible if you think about it (once you have got the calculator open).
Jim
Posted on Mar 19, 2009
Hello! So, if I am correctly understanding your problem (sorry it's a requirement to re-state the question), is that you can't see the numbers but the actual math is working fine.  You might know that there are solar-powered calculators, which are powered by light, hence the word "solar." There are also battery powered calculators too.  Then there are what I like to call "hybrid calculators" because they are a combination of both.  For just normal solar-powered calculators, they only work with light, and with battery powered only by batteries. The "hybrid" calculators run on battery, but have a solar panel for backup. So the problem might be two possible problems that I am seeing. One being, the battery ran out and the solar-panel is really crappy, so there might be need for a new battery. Second being, the battery ran out and the solar panel is in an area of just not enough light to supply power.  And if it is just a solar panel calculator then you will see a little box indented on then top of the calculator, on the front side, with little lines separating it into little squares; and you may need more light.  And if it is just battery powered you will see, on the back of the calculator, a little box screwed in which is where the batteries are held.  If it is a hybrid it will have both. And one thing that had escaped me before is that the screen of the calculator could be cracked somewhere, and the ink be spilling out.  I am sincerely sorry if I am totally wrong about this calculator, as I have never used or even seen one.  I am sorry if I have wasted your time, and I hope this helps. I wish you great luck! =)
Posted on Jan 18, 2009
Whats the short cut to get to calc screen
If by calc screen you mean HOME you usually get back to it whenever you interrupt the execution of a command. You can also go to HOME by pressing RIGHT SHIFT (Cyan) key then the appostrophe (below MTH). That returns you to the HOME directory. To set the menus to the default ones, press MTH
Apr 19, 2012 | HP 48gx Calculator
HP Dv9800 Blank Display
have you checked all the wiring connections are they firmly connected.
Oct 06, 2008 | HP Pavilion dv9000z Notebook
Hp pavilionn dv6700 screen goes black after a while
If you shine a flashlight on your black screen and look real hard for the icons on the desktop. If you can faintly see them that means your LCD Inverter is bad. You'll have to disassemble the LCD Screen to get to it. In the mean time you can attach another monitor (LCD Flat Screen or the Old style fat CRT) with a VGA cable to the vga port on you laptop. Once you have it connected hit the FN (Function Key) + (F1 thru F12) key that that corresponds to the external display. Hold the FN Key while you hit the Function Key that is for the external display. The key might have the words LCD/CRT on it or it might show a display symbol. That's the key you want to hit while holding down the FN key. This will cause the desktop to display on the external monitor and verify that there is no problem with your Video Card inside the laptop.
Mar 15, 2012 | Computers & Internet
HP 48gx Calculator seems to turn on but display does not show
It might be too dim.
Turn calculator ON. Then press the ON button and hold pressure. Press the PLUS + repeatedly until screen darkens.
Nov 17, 2010 | HP 48gx Calculator
Viewsonic vp2000s LCD computer monitor - no image displayed; possible backlight outage.
It is possible that the backlight has quit working. Use a flashlight, held at an angle to the display, to see if there is a faint image visible. If so, then have backlight repaired. Otherwise, try a different input / cable.
Aug 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
My HP 48G does not come on.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
You can also try this site. They do repairs on most models, except the newer ones.
Hope it helps and Thank you for using FixYa.
Do not forget to rate the solution.
Nov 29, 2009 | HP 48gx Calculator
Hi. I have 2 HP calculators (48S and 48GX)that both have the same problem. All of the soft keys, the on switch, and some function keys do not work unless I squeeze the calculator on the metal bezel just...
I suppose you can have them repaired, but I suggest you purchase an HP49G+ or an HP50g. I own a 48g and just bought a second hand HP49G+. It is something else: larger screen, 75Mhz processor, about 1.5Mb RAM, an SD card slot (up to 2Gb), RPN, algebraic, and CAS modes, USB and IrDA connectivity, etc.You can even make them work as a 48gx with software from HP web site.
Note that repairing two discontinued models, with the possible scarcity of parts, may prove expensive.
Hope it helps.
Sep 13, 2009 | HP 48gx Calculator
Sharp microwave r610dsa - display faint - barely visible.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
If you decide to send yours in for repair, we would really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the manual.
If you prefer, you can order part number DPWBFC212WRKZ (CPU/display unit) for $73.33 plus shipping from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 08, 2009 | Sharp Microwave Ovens
HP 48gx Calculator Logo
540 people viewed this question
Ben Johnson
