Question about Hoover Washing Machines
DOOR LOCK LIGHT IS FLASHING
HOOVER DYN DG DOOR LIGHT IS FLASHING ERROR 1 AND MACHINE WONT START I HAVE LOOKED AT DOOR LOCK MOTOR BRUSHES PUMP BUT NO JOY.
  • 641 Answers
SOURCE: Motor brushes?
I am not familiar with your specific washer, but there are some washers that has a hole in the bottom that allow you an access to the brush. In case you don't have this access (I hope that you will have !) you should take the motor off for it. Good luck !
Posted on Jun 12, 2006
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Posted on Dec 10, 2007
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
cerikitten
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
I have hoover Optima wmh139 with lights flashing from left to right it's 1 2 5 how do you read fault
here are what the numbers mean. 5 is probably throwing the others but you'll need a service tech to know for sure.
have you unplugged/cut off power to it for 10 min to see if it may possibly reset? Worth a try anyway.
Error 1 Door safety lock error
  • Check door is closed and latched correctly
  • Check wiring
  • Check door lock
  • Check drum braking device if fitted
Error 2 Not filled in preset time allowed - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
Error 3 Not drained in time allowed - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Error 4 Multiple instances of anti-flood contacts in pressure switch being made
  • Check for overfoaming evidence - can trip pressure switch
  • Check pressure switch is not defective
  • Water inlet valve locked open
Error 5 NTC fault - temperature sensor detected as either open circuit or shorted
  • Check wiring to temperature sensor
  • Check thermistor
Error 6 EEPROM failure - defective electronic controller
  • Check wiring
  • Check electronic control PCB
Error 7 Motor fault detected
  • Check motor connector block
  • Check wiring
  • Check motor carbon brushes
  • Check tacho connections
  • Check motor
Error 8 Motor tacho fault - washing machine motor tacho detected as open circuit or shorted
  • Check wiring
  • Check motor
Error 9 Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Error 12 Communication error between electronic control boards and wiring
  • Check wiring and harness between control boards
  • Check electronic control modules
Error 13 Communication error between boards and wiring
Error 14 Water heating error detected
  • Check wiring to wash heater and thermostats
  • Check wash heater for continuity
  • Check NTC (temperature sensor) probe
Error 15 Defective control module - Not programmed Cuore control
  • Reprogram electronic controller
  • Replace electronic controller
Error 16 Water heating element detected as short circuit
  • Check for defective electrical insulation
  • Check water heating element
  • Check water heater wiring
Error 17 Wrong signal from motor tachometric generator
  • Check wiring
  • Check motor
Error 18 Defective control module - also can be wrong electrical input frequency
  • Check wiring to electronic controller or both if two used
  • Check electrical input frequency
  • Check mains electrical supply
Feb 26, 2018 | Hoover Washing Machines
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover DYN 9144 DG - 80
washing machine won't start. display screen is flashing constantly, no error codes up. does any one know what the problem is??
Mar 23, 2013 | Hoover Washing Machines
Hoover H160E - stops with lights flashing 4 times (cyclic)... suaully before aspin cycle... appears to be incomplete drain (drains until no water viisble in drum - but still significant water at drain.....
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
Go for it ;-0)
John C
Feb 26, 2011 | Hoover H160E Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Oct 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
