Question about Bowflex Treadclimber
Installing treadclimber tc6000 belt
The walking belt, so far we had belts, felt they were sized wrong, returned, now the treads are apart, can get belts on but can not get the rollers alined. So far, just about everything is apart, any suggestions?
4 Suggested Answers
  • 4 Answers
SOURCE: we canNOT get the belt
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
Posted on Sep 03, 2010
ercupa190
  • 12223 Answers
SOURCE: walking belt jammed under adjustment guide
see the videos and execute with common sense.
God bless you
Posted on Sep 17, 2012
  • 15 Answers
SOURCE: Walk tread keps silding against maching and fraying belt
You should be able to adjust it on the end of the belt with some screws...tighten or loosen them...or one tighten and one loosen, Play with that and it should help you out.
Posted on Oct 16, 2012
Why treadclimber shuts down Level 1, 2.5 mph in treadmill position
Will be 4 reasons;
1) Drive belt too tight loose the bolts motor, until deflection
1/8"
2) Too tight the walking belt, How To Adjust Treadmill Belt
3) Lube the walking belt with WD-40 with slight Maintenance Lubricating the Walking Belt
4) Controller board motor defective.
Blessing
cuadra2016@yandex.com
whatsApp:+50588611441
Oct 31, 2017 | Exercise & Fitness
How do I replace a tread mill belt
Not a small task. You have to remove rollers and deck if you are doing this flip your deck as it is probably due and clean rollers since you have everything apart. Good luck
Jul 15, 2014 | Weslo Cadence Lx25 Treadmill Walking Belt
Walking Belt Fraying
The bow flex tc5 is an overpriced piece of equipment. The build quality is not great. There are ongoing documented problems with the belts fraying on this model. You can always order a new belt or adjust the side (loosening or tightening) your primary foot stepping side, but I would call bow flex and demand a new belt or replacement. You can mention there is a "risk of fall" due to poor workmanship. This will get their attention and you may even get a new treadmill or at least free belt. Call Bow flex customer service at 1-800-436-6549.
Mar 18, 2014 | Bowflex TreadClimber TC5
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
There is a knocking sound coming from bottom of machine when belt moves.
The treadclimber is a nonsense scam and they are the cheapest made product on the market. You are better off throwing that thing in the trash than paying to have it fixed.
Aug 06, 2017 | Bowflex Treadclimber
The tread is slipping while walking
The belts are too loose. The owner's manual includes instructions on how to properly tension them, you can download a free copy from the Bowflex web site.
Jan 16, 2013 | Bowflex TC1000 Treadclimber
Oct 16, 2012 | Bowflex Treadclimber
We canNOT get the belt on the new treadclimber - there's no give and it's just not going
Aug 28, 2010 | Bowflex Treadclimber
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
Bowflex treadclimber 5000
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
42 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
