Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Software setup won't automatically run
Just bought it. I have OSX 10.5 system. How do I get the setup to run?
The disc may not have the driver for MAC OS. you should go to canon website and download the driver for MAC OS and new firmware too.
most USB print server in the market will not work with Canon MF4350D because it does not support postscript printing :-( I had to use VMWare + Windows XP for network share and print.
Posted on Jun 14, 2009
In sert disc on the computer, goto your computer se t up ans select run.
Posted on Jan 18, 2009
Operating System Requirements
No Problem
Always do a full backup before updating your Mac OSX. Use Carbon Copy Cloner to make a bootable "Clone" of your current Hard Disk. Once the clone is done... Boot from the clone. (Hold Option Key down at Startup and choose external HardDrive with new clone OSX)
Verify that this clone Boots & has all of your current data.
Use the "Mac Tracker" App on the Mac or iPhone to see what the maximum OSX system your model can handle. (Makes no sense in installing just OSX10.5 if you can go to say OSX10.7
Download a copy of the MacOSX 10.5.8 installer DVD (Saved as a .DMG file here Fenopy.se (Search for OSX 10.5). OR OSX10.9 (free download) if your Mac can run on this latest OSX.
Burn your OSX Install software to DVD. Use Disk Utility with your .DMG (Disk Image) File and select the .dmg from the LH Side menu to burn to DVD.
Once burned, try booting from the DVD. If that works OK then you are ready to go. BUT not quite yet.
You really don't want to install a new clean system over top of your existing system. This would be like a Band Aid Fix.
(This is where you must have your current existing system cloned to an external hard drive. Just like i mentioned above.)
Because, now you will start up or "boot" your computer from the DVD installer disk you just made. You will find the Disk Utility tool in the top menu. Use this to FORMAT your internal Hard Drive. (Dont Have your External Drives connected at this time... for safety.)
Choose ERASE or Partition and Select "Mac OS Extended (Journaled)" as the format type.
This process only takes a few minutes. If you have more time you can select the Security Option (choose fastest or single pass) then hit erase button. The security option in this case is only used to write "ones" to every sector on the disk thereby thoroughly testing the drive. This happens to be the ideal time to make sure you have a good flawless internal hard drive. Peace of Mind for older Macs.
Once completed, your drive is totally empty, you have lost everything unless you have made a "clone" beforehand.
Now you can run the installer and leave that process to complete for half an hour or so.
When installer has finished the Mac should reboot itself (you will hear install Jingle), with the new clean OSX installed. You can then manually answer all the questions if you want and give it your Network passwords etc. OR You can select Migration Assistant and migrate all your previous files & settings automatically from that external drive "clone" you made earlier.
You should now have almost a brand new clean Mac to install your new scanner software on.
Also... if you only installed say OSX10.5.0 then you will have updates to download on line, then install, to bring your Mac up to 10.5.8
I run this process on my Mac's at least once a year so that I always have a clean OSX with defragged hard drive so I can work reliably for the next few months. If not... I still have my "Clone" to boot from.
By the way Apple's latest systems since 10.7 (I Think) have an emergency boot partition automatically installed by the installer software. You just re boot & hold the OPTION KEY down and you are given the choice of booting from this bare minimum emergency system. It is heavily limited as to it's functionality but Disk Utility is there to look for problems.)
Good Luck
Feb 21, 2014 | Apple Mac OS X v10.5 Leopard
Joey
If you have another (mac) pc available, you can create a USB key with your MAC OSx install disk. Put it in a USB port, and reboot. If there is no hardware malfunction, it will start the installer, and you can try to 'fix' the installation.
http://www.techrepublic.com/blog/apple-in-the-enterprise/how-to-create-a-bootable-usb-to-install-os-x/
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
I recently upgraded my operating system (to Mac OSX 10.6) and now my VCI-100 won't show up as a device. Any advice on how to resolve this?
Here is an online manual, Can't download it, though. Hope it helps.
http://www.manualslib.com/manual/399951/Vestax-Vci-100.html
Mar 10, 2012 | Vestax Vci 100 Midi Controller
How do I set up a valet m20 router with a computer that runs windows xp 2000?
Welcome to FixYa!
If you still have the installation disc that came with the router, you can go ahead and run the disc and follow the instructions. The Cisco Connect Software will be installed when you run the supplied Setup CD or Easy Setup Key on a computer. Once Cisco Connect is installed, you can then use its features to easily manage and share your network resources.
QUICK TIP: Create a Desktop shortcut to launch Cisco Connect easier.
Windows XP
Step 1:
Click on the kb21465-001_en.png button and select All programs.
Step 2:
On the All Programs sub-menu, locate and select Cisco Connect. This should launch Cisco Connect and take you to its main screen.
NOTE: If you are unable to locate Cisco Connect, it may not be installed yet. Download the latest Cisco Connect setup wizard from the Cisco Support page. After downloading, click on the Cisco Connect icon to launch the installation wizard.
Hope this will help...Thank you for using Fixya...
Feb 28, 2011 | Computers & Internet
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
Modem seems incompatible with my OSX 10.4.11
Using a good computer connected to the internet, logon to netcomm using this number NB7PLUS4W and download the drivers for your operating system OSX 10.4.11 and that should fix your problem.
Good Luck
Fehdi
Apr 15, 2009 | Computers & Internet
Hi, I just bought a clamshell ibook for my 9 yr. old. It has upgraded ram and Mhz. I'm afraid something is wrong with it. It takes FOREVER to load, makes a loud noise, and (although it has and airport...
Hi Sahemric,
What OS is running on your system also, OS9 or OSX. I've got to wrack my brain to remember how to check in OS9 (it's been about 6yrs since I last used it) but in OSX it's very simple. Goto the apple symbol in the menu bar choose 'About this mac' then 'more info...' and in the left hand 'Contents' panel in the 'Network' section is 'AirPort Card'. Select that and if it says 'No information found' then you ain't got it! Otherwise it will give you the Make, model and settings.
If you have got one then the setup is different for each version of the OS so again I'd need that but that should get you part way there
All the best
Sean
Dec 15, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
323 people viewed this question
old marine
old marine
