Question about X2Gen MG19MY 19" LCD Monitor
I need a power cord for my x2gen 19" in monitor
Ad-1250B is model # for 12 volt powere source
  • psghamm Jan 19, 2009
    monitor won't come on. at first the screen was black and the blue power light was blinking. now it won't come on at all. the light on the adapter comes on.
    Genius:
  • 2,120 Answers
Check eBay
Posted on Jan 18, 2009
X2gen 19" monitor
I would recommend geting a new transformer, althought its possible that there is a connection loss somewhere in the middle or then it would require replacement parts, does the transformer have a power light on it?
Shouldnt cost alot, checking.
Apr 04, 2008 | X2Gen MG19MY 19" LCD Monitor
My power cord does not work anymore, i need to purchase another one, i was wondering what the price would be
http://cgi.ebay.co.uk/12V-X2Gen-MG19VT-replacement-power-supply-/400197777357?pt=LH_DefaultDomain_3&hash=item5d2da577cd
Mar 03, 2011 | X2Gen MG19VT 19" LCD Monitor
I have x2Gen 19" LCD Monitor. I hooked up the
More likely to be the fuse for the backlight inverter circuits rated at 3.5 or 4Amps. It is PICO fuse.
The transistors that drive the inverter transformers may have been damaged, should check them out before installin a new fuse. In the mean time you can use 1 to 2 Ohms 1/2 Metal Oxide (MOX) resistor in place of the fuse, if the resistor overheatand open up then you have shorts circuits.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 19, 2010 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
Replacement power plug
Hi...there,
You mean you got a dead power brick (AC Adapter)??? If you so, you can order one @ www.3rd-rocks.com
Apr 28, 2008 | X2Gen MG19MY 19" LCD Monitor
Need new power cord for x2gen monitor
You should be able to go to any local store like BestBuy and pick up a power cable. The monitor uses the same power cable as a Desktop PC.
Here is a picture: http://www.cablestogo.com/product.asp?cat%5Fid=914&sku=03129
Mar 14, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
150 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
