Brake indicator light stays on
After I start the car, release the emergency brake and drive a few feet the break indicator light on my dash comes on. Why?
  • 716 Answers
You Need Brakes Or Brake Fluid.
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Posted on Jan 18, 2009
Hand break light coming on with out using hand break
The cable tightness is loose therefore causing the light to come on while driving, tighten or replace the eb cable hope that helps or you need to push in the button on it hold the button and pull it back as far as you can. let go then push button pull back farther and release, this should tighten the tension.
Jan 02, 2015 | 1994 Chevrolet C1500
What causes the dash brake indicator to stay on?
First of all, the abs problem... NO do not start there, start with checking your brake fluid.. thats the number one cause for that light and no other lights on your dash to be on... if that is your problem fill it up and address the brake leak... brake fluid doesnt evaporate and your car doesnt use it up. if its low its going some where best way to do this is park on a clean surface or slide cardboard under your car pump your brakes 10 times and then examine the cardboard or move the car and look for wet spots that wernt there before or you could also have a friend lay on the ground a few feet back and look for drips while your pressing the brake pedal careful not to get any brake fluid in the eye it burns like no other... if you find a leak have it fixed if you dont it might still be a internal leak into the power brake booster and you should have someone look at it NORMALLY when you have a ABS problem with you car BOTH THE ABS LIGHT AND BRAKE LIGHT will be on not just one but the other awnsers could be correct too the brake indicator light does come on when the emergancy or parking brake is enabled try pulling the release and pull up on the parking brake pedal at the same time.. or if its a center parking brake push it all the way down with the button pushed
Apr 29, 2014 | 1998 Chevrolet K2500
What would make the break lights on the outside stay on the whole time you are driving? Emergency break isnt on. 99 mercury cougar
Your brake switch is probably stuck. It is located under the dash in the cab, above the pedals. It is a chrome looking cylinder. It has a button on the end of it, when you push the break in, it releases the button. It is probably stuck.
Feb 06, 2011 | 1999 Mercury Cougar
Brake light on dash stays on even when the emergency brake is released
That brake light also indicates when your brake fluid is low. Check your brake fluid level in the master cylinder reservoir and add some if necessary. Also, check the braking system for leaks.
Nov 03, 2010 | 2004 Nissan Maxima
When I start the car brake light on the dashboard is on.my foot is not on the brake pedal.the brake lights on the back of the car are not on.when I drive around the light is still on.
That break light usually means the parking break is on. Check to make sure that is released all the way. Even one click on will turn on the light.
Oct 05, 2010 | 1998 Toyota Corolla
Emergency brake light stays on the dash. is it a troubleshooting light?
It probably indicates that the cable is not being fully retracted when brake is disengaged. Spray as much of cable as possible with WD-40, allow to sit for a few hours, the engage and disengage the brake several times untill it loosens. If this fails the cable may be stretched and needs to be replaced.
Jun 25, 2010 | 1996 GMC Yukon
Dash brake light indicator stays on while emergency brake is released
There might be to different issues, the emergency brake switch is broken ,normally is located in the end of the handle, or the brake fluid reservoir is below the mark either due to a leak or wear in the brake linen,
Jun 16, 2010 | 1994 Nissan Pickup
04 Corolla "BRAKE" light on dash--comes on occasionally??
I wouldn't drive it... when your brake light comes on, it means there's a serious fault with your brakes. They may not engage when you brake and there won't be any further warning other than the brake light
Sep 09, 2009 | 2004 Toyota Corolla
Break light....
There's a switch on your emergency brake that the indicator (on your dashlight) operates from. Sometimes it slips in its bracket and gets out of adjustment causing your dash light to stay on. Its located on the upper part of your emergency brake pedal. Hope this works for you. Goodluck.
Aug 25, 2008 | 1988 Chevrolet C1500
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
