Question about Microwave Ovens
I have an Amana microwave Model RRL-10C. The magnetron modulation SCR has delaminated from the foot mount and shorted in the closed position due to thermal failure(thank goodness the nuke still works but the defrost and powermatic on/off levels do not work). Is there a schematic diagram available for this machine including the control model that would list the part number for the SCR. I 'm not sure if the SCR has cascaded and taken out the predriver as well, A detailed schematic would solve all my problems. These machines are very simple, a simple part number would be great. Thank You
  • 2 more comments
  • mebaskin Jan 18, 2009
    Thank you for responding. The triac appears to resemble your photo top row second from left. It has three solder ring leads. Appears to look like a classical TO3 case inverted (two drill through mounting holes in the oval heatsink base)
    A part number on top (what I can determine) looks like #M SAC358 or 359?
    If the opto has lost it's smoke,could I substitute an external solid state relay in place of the triac and peal off the DC/AC modulation trigger prior to the opto? I'v got a bunch of surplus SSR's in the basement just longing to to their job.
    A schematic of the PCB would make things very simple>
    Thanks Again
    Thanks for all your help. The part number for the triac looks great.
    I know I could go out and buy something new,but these old nukes just have something appealing about them.
    Thanks Again
  • William Miller
    William Miller May 11, 2010
    Actually, it's not an SCR, but a triac, which is essentially two SCRs mounted in an opposite parallel configuration.
    What part numbers are on the case of the triac?
    Are its leads soldered on ring terminals or are they slip-on "Fast-On" type connectors?
    I can probably suggest a cross / generic replacement part.
    Can you post a photo, too?
    Just be aware that a resistor or optocoupler in the control circuit may also have blown too. That's not uncommon.
    It may look like one of these - if so, which?
  • Microwave Ovens Master
  • 9,098 Answers
I wouldn't suggest trying to modify the triac control circuit.
Without a schematic I couldn't begin to advise you on how to do that or to value or the parts that might be bad.
And I truly doubt that the schematic can be found.
I would kind of expect the opto to be bad, and maybe a resistor or two.
They would need to be replaced with the right values and an acceptable opto.
You may get lucky and find that the opto and resistors are all okay.
You can find the triac here. Looks like the GLC16-50 or GLC16-50S would work for you.
That's about all the help anyone can provide you, honestly.
Good luck and be careful!
Posted on Jan 18, 2009
My Amana Radarange over the stove microwave started to omit a "burnt rubber" smell and stopped defrosting or heating anything all of a sudden. Model #MVH15W. Still works otherwise, lights on...
You're describing a common smell that goes along with a magnetron tube that has failed. The magnetron tube makes the microwaves, and will eventually fail if you keep a microwave long enough. They can fail in a couple of different ways, and one is to short out accompanied by that burning smell. It's probably not worth trying to repair your oven because of its age. I don't believe the magnetron is available any longer. If it is, it will be costly, and replacing the tube is best left to a professional because of safety concerns. Your most economical choice would be to replace the oven.
Feb 28, 2011 | Amana Microwave Ovens
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
I'm trying to find a replacement glass tray for my Amana microwave oven. The model number is RRL-10TD. The date on the back of the oven is 1982.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
Jan 11, 2011 | Amana Microwave Ovens
Microwave turns on but does not heat.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Oct 31, 2010 | Amana ACO1840A Microwave Oven
Microwave work for 2 minut and turns off and after 5min its turns back on and do same thing
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (US homes should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
I would suspect a failure or the fan, clogged filter or bad magnetron.
You didn't mention your brand or model number, so I'm limited to general advice.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
May 26, 2010 | Amana RFS12MPS Microwave Oven
Microwave will not heat up. All else is working normally.
either you have an electronic part called a "triac or SCR that fires the magnetron circuit that is bad on the circuit board, or the H.V. Diode is leaking in the same circuit,but this is near the H.V. capacitor and magnetron components and can't help in supplying high-voltage( -D.C.) to operate the magnetron circuit,it might be the H.V. capacitor, but normally they don't open, but if if they short circuit,the internal fuse will open up
Feb 23, 2010 | General Electric Microwave Oven
Amana microwave is loud and doesn't heat. Light
Magnetron went out causing a short-circuit of sorts. Replace magnetron.
Jun 29, 2009 | Amana MVH320 Microwave Oven
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
Amana Microwave Problem
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | Microwave Ovens
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
