Question about Panasonic TY-LA1000 Projector Lamp for PT60LC1
I have a panasonic model pt-52lcx15 and replaced the lamp part # ty-la1000. It works fine but I can't figure out how to reset the timer, do you have instructions for this, they weren't included with the new lamp.
  • Anonymous Apr 24, 2009
    how to reset time
  • Lola Addiego May 14, 2009
    I had the same problem and followed your instructions and it worked perfectly. I wish I would have checked this two months ago when I first got the message! Thank you.
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Posted on May 14, 2009
I have ordered a ty-la1000 lamp for my panasonic pt50lc14 tv. the manual gives no information as to how to rset the lamp timer. please advise
I noticed that the manual on the below website has more information and instructions than the one that came with the tv on how to replace the bulb and reset the lamp timer, etc. Easy to do but they told me two years ago I had to have it done by a technician which costed me $300.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Dec 08, 2010 | Televison & Video
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
I need to replace the lamp...how do i get it out?
Hi, well your TV uses the lamp enclosure TY-LA1000, here is a link where you can find the manual of how to get to the enclosure http://www.fixyourdlp.com/blog/2007/09/17/panasonic-ty-la1000-enclosure-replacement-instructions-guide/ and here is another one to replace the lamp on the enclosure http://guides.fixyourdlp.com/panasonic/TY-LA1000.php
Jun 27, 2009 | Panasonic PT-52LCX65 44" HDTV
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
1,321 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
