Question about Groups RECHARGEABLE WIRELESS SOUND SYSTEM FOR LARGE 40W AMP 8 SPEAKER Apollo Microphone
MYT APOLLO 6000N WILL NOT TAKE A CHARGE ANY LONGER
MY amp. is about 5 year old, and no longer take a charge to play with-out power. Where is replacement for the Batt. or where is location, and who can repair it, or change the Batt.?????
  • revchacon Jan 22, 2009
    Thank you for the information. I used it with elect. Power from where I am at, and if it breaks I just take to the local repair place, and when it gone it will real old, and time for a up-grade. Buy American, and you same results.. It works good now.. thanks all
Buy a new battery pack for your PA-6000 at AVTS Parts Fulfillment Center
item PA6000-05 battery pack 18v at www.pegasusavproducts.us
Posted on Jan 05, 2011
  • jewlsiyq Jun 02, 2011
    My newer Apollo has the battery sealed inside... anyone know how to open that compartment to change the battery if I do by a new one? My really old Apollo you can change the battery I can get it at batteries plus for $50... But I had them look at my new one he also said wow why would they do that??? Stupid me bought it brand new on ebay because I LOVED my old system used it for years.... Need it to be wireless for out door gigs. Suggestions needed!
I have the same problem. I did take the amplifier apart and found that the battery is down in side and requires taking componets out to get to it. As of yet I am not sure that the battery is the problem. I have not been able to find a wiring diagram to check it out. I have recently bought a second PA 6000 to which I can use to trace voltages. It is possibly that the power board has a part that quits working.
So if there is any one with a solution I too would like to hear about it. Thanks
Posted on Jan 19, 2009
  • hamie401 Jan 22, 2009
    I spoke with the Boone company this morning, they don't have anything to do with the amplifiers and referred me to a number for Apollo.
    When I called that number the lady answered as Vutec not Apollo. The Apollo amplifiers were discontinued several years ago, they do not service them, they do not carry spare parts for them, and they do not have a wiring diagram for them.
  • raybreally Jan 05, 2011
    check AVTS Parts Fulfillment Center their shop online has all the spare parts for your Apollo PA Systems. www.pegasusavproducts.us
    You just need to buy the PA6000-05 Battery Pack 18v
Why is my battery always running out of power need to charge every night
When a battery is 3 years old or more expect it to no longer hold a charge. Time for a new battery
Jun 22, 2017 | Power Computers & Internet
2003 Mitsubishi battery goes dead overnight
either the battery is no longer holding a charge if it is more than 5 years old good bet the plates are worn otherwise you may have a short in it that stays on after you power off the car
Sep 23, 2014 | Cars & Trucks
Hi my I phone is not charging while it is on and when switch off it start charging???
Hi -
It is not uncommon for some devices to be unable to accept a charge while in use - especially if not using the supplied charger. This is because the amount of power required to USE the device (your iPhone in this case) exceeds the amount of power provided by the charger.
If trying to make a call, you may be able to coax your iPhone to accept a charge if you shut down un-needed services such as wifi, GPS and BlueTooth radios along with turning the brightness of the display down, etc. This greatly reduces the power requirements of the phone; and if the charger is powerful enough, it will begin to slowly charge your phone. The charge rate will be significantly lower - requiring a longer time on the charger - whenever the phone is being used AND charged. Once the phone is no longer being used, the charge rate will immediately increase, since AC power no longer has to be divided between charging the battery and operating the phone lights, radio, etc. This shortens the amount of time needed to recharge, significantly.
Whenever possible, use the the supplied charger - or one with the SAME voltage, polarity, and voltage type (AC or DC). The amount of current or wattage should be the same or greater than the original. Most phones use USB connectors and are 5 Volts DC. USB standards call for between 1/2 and 1 Amp current. Since watts is equal to volts x amps, this example would represent a 2.5 (if 1/2 amp) to 5 (if 1 amp) watt charger. If you could find a higher wattage charger while still maintaining the DC voltage requirements, you would be able to use and charge the phone at the same time.
I hope this answers your charger question & good luck!
Sep 04, 2012 | Cell Phones
The Laptop Dell, Inspiron Series 1526 model does not power on after keeping off for a longer time ( for 4 to 5 hours. ) Kindly tell me, what could be the reason ?
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 04, 2011 | Computers & Internet
Battery doesn't hold a charge - 1 hr play from the start - even thought I have charged up to 5 hours
How old is it ?? Try and charge it over night-- It should operate longer than 1 hr. Maybe bring it back for exchange.. ?
Jan 28, 2010 | SanDisk Sansa Clip MP3 Player
The battery charger in the trasfer case is not charging the battery
have you tested the battery to see if its a good one? if its a dud it wont charge up, and whet tests have you done to see if it realy is not charging the battery, the times iv had this,,, its not charging,,, when it was, but the battery was a dud,
however check all the fuses and trips and put an avo meeter set to amps x10 in line with the battery after you have started the charget to see if it realy is not charging up,,, if its not look at the rectifier,,it may have a blown diodes in it
Nov 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
1,190 people viewed this question
Top Groups Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Groups Audio Player and Recorder Expert? Answer questions, earn points and help others
