Question about Frigidaire FRT18G6J Top Freezer Side by Side Refrigerator
Freezer temperature won't get cold enough.
We recently bought a Frigidaire top freezer FRT18G6J. The refrigerator temperature is fine. When I placed a thermometer in the freezer section -- it does not get into the freezer zone -- it stays in the refrigerator safe temperature zone. The freezer is located in our unheated garage -- but the freezer hasn't been in frozen temperature degrees during the summer or now during winter weather. Any ideas? Thanks.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Posted on Jan 18, 2009
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
Frigh won't get cold enough
check the slot between the freezer and fridge with this model the freezer cools the fridge there a door in the slot make sure it is opening properly
May 26, 2012 | Frigidaire FRT18P5A Top Freezer...
Freezer seems to be working fine. refrigator does not seem to be cold enough
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 01, 2010 | Frigidaire FRT17G4B Top Freezer...
Frigidaire ref not cold
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 29, 2010 | Frigidaire PLRU1777DS Stainless Steel...
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator not cold enough
yes, if theres a warranty on it, call the place you bought it and have them send out a service tech. you should not have to pay anything.
Apr 22, 2009 | Frigidaire FRT17G4B Top Freezer...
The freezer is cold, but has stopped freezing,
This may be as simple as just turning the temperature dial for the freezer to a colder setting. Do that and wait a few hours and your problem may be solved.
Feb 06, 2009 | Frigidaire FRT21H8 Top Freezer...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Jul 11, 2008 | Frigidaire FRT21P5A Top Freezer...
Frigidaire FRT18G6J Top Freezer Side by Side Refrigerator Logo
360 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
