Question about Amana 12527304 Refrigerator Water Filter - Clean n Clear WF401 - 6 Pa
Where can i find a bypass for 12527304 Amana Clean \'n Clear Refrigerator Water Filter
aborcass
  • 2651 Answers
SOURCE: Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Posted on Nov 16, 2008
  • 103 Answers
SOURCE: I cant get my refrigerator unlocked
Hi: I don't know if you have the manual, but you have to hold down the lock button down for several seconds to release it. That how it works. I hope this helps and you don't need service. As a last resort unplug the fridge for an hour ( don't open it in the interim) then plug it back in and see if it resets. I hope this helps, Jeff
Posted on Jun 01, 2009
bobicehouse
  • 1524 Answers
SOURCE: We have a Amana refrigerator Model # SXD22SW2 and
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Posted on Oct 13, 2010
heatman101
  • 43501 Answers
SOURCE: Our Amana bottom freezer refrigerator is too cold
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Jul 12, 2011
oldTech2332
  • 2341 Answers
SOURCE: Where is the water filter
your water filter is in the upper right hand corner of the fresh food (refrig.) compartment above the upper most shelf in the ceiling
GENE
Posted on Aug 27, 2011
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Nov 14, 2015 | Amana Refrigerators
NEED A TECH/REPAIR PERSON TO COME TO MY HOME TO REPAIR WASHER. OUT SINCE JULY 7,2014? HELP ME PLEASE
Amana appliances are now produced by Whirlpool Corp., who purchased Maytag Corp., (previous owner of brand). Whirlpool maintains the previous Maytag parts and repair call center in Cleveland, Tenn. The phone number in your operating manual, even if purchased prior to Whirlpool takeover, for repair should still be good.
Oct 14, 2014 | Amana Clean n Clear Water Filter 12527304,...
I need to clear the drain line on my Amana ARB1917 bottom freezer refrigerator. I've accessed the short tube that is supposed to move the water from the fridge/freezer to the drain pan ... it's...
The way to check that everything is clear pour some water over the evaperator coil in the freezer and see that the water drains very quickly. Also you could use a can of compressed air that you would use to clean the keyboadr and what not on your computer and blow it in drain and clear anything remaining
Gene
Aug 03, 2011 | Refrigerators
Amana model# SZD23VE refrigerator were is the water filter? or does it even have a water filter?
Yes it has a water filter option. The water filter housing is in the refrigerator near the top of the unit. You need to twist the old filter itself to the left to remove. (You will be removing a cover that you need to take off the old filter and put on the new filter. This cover can also be replaced without a filter to bypass the filter. The part number for the filter is AP4310541, http://www.appliancepartspros.com/part_details.aspx?part_id=4310541 .
I hope this helps.
Apr 09, 2011 | Amana Refrigerators
I have an amana asd2626hew side by side with a new water valve but i still have no water at the door. how do you check to see if the water line is frozen?
did you connect dual valve correctly if not icemaker could be filling when you try to get water out of dispensor also a way to check if your dispensor paddle and switch test ..... otherwise possible plugged water filter or bypass cap not installed in filter head... is water supply on to water valve
Jan 28, 2011 | Amana ASD 2624 Side by Side Refrigerator
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
I have an amana refridgerator with the ice maker and water dispencer. Neither one is working anymore and I was wondering if you could help in this problem?
Use the blue bypass cap which came with your refrigerator and check to see if the water filter is clogged. With the bypass installed you should get water from dispenser. If no water even with the bypass cap installed, check your water source and make sure it is turned on and no kinks to the connection line to the refrigerator. If you are 100% sure your water source is good TO the unit, then your Filter/Head assembly is not working properly.
Mar 29, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Where is the filter on a Amana SQD23VW
CLICK HERE for all the blowout diagrams of your fridge.
CLICK HERE for your Owner's Manual in PDF format.
CLICK HERE for your Installation Instructions.
The water filter is found in rear right corner of refrigerator section. Twist cartridge counterclockwise 1/4 turn and pull down to remove.
Some fridge model levels did not have a filter and you will find a bypass cartridge there instead.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Filter change
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Cleaning the water system
A possible solution is depending on your water source... Chlorine will kill the algae, mold & mildew but the filter blocks chlorine. What we tell people is if you have chlorinated water, remove the filter (a bypass device may be needed depending on the make/model) and run without the filter for a week or so. The chlorine will kill all that stuff and then you can run the filter again. If you don't have chlorinated water you would have to mix a solution of bleach/water in a tank of some type and then use a pump (usually a Sur-Flo RV type pump) to supply the pressure and run a few gallons of chlorinated water through the system (again without filter) then let it sit 24 hours to kill the gunk. After that hook up to normal water supply and flush the system until there is no chlorine smell. The ratios for bleach/water, etc. are available on the internet if you "Google" the process.
Feb 02, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana 12527304 Refrigerator Water Filter - Clean n Clear WF401 - 6 Pa Logo
63 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
