Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Printer issues my computer will not communicate with my lexmark printer I have loaded up software set up
  • 81 Answers
Well the primary reason for a communication problem in case of printers is either that the physical connection of the printer is not proper place... or i would recommend you to first uninstall the entire lexmark software...
And then reinstall the software from the Cd's that you recieved with the printer & just make sure that when you start installing the software at that time the printer c able should be disconnected from the system & reconnect the cable only when the software will ask you to connect in the process of reinstalling the software....
Posted on Jan 18, 2009
Have a Lexmark Prestige Pro 805. I was using this printer and it worked perfectly until I moved it to my daughter's computer. Both of our computer's are the same. I loaded the installation software
You installed the drivers for the printer but you still need to select that printer as the default. Computers can have many printers connected to them so you will have to tell the computer to print to that printer. Go to your start menu and click on "Devices and Printers". If your printer is listed then all you have to do is right click on the icon of your printer and select "Set as default printer". If it is not listed then you can click on "Add a printer" at the top of the window, select "Add a local printer" and follow the instructions on adding your printer to the computer. Then you can set it as default like before. This may not be your problem but its worth checking to see that it is set as the default printer. If its not that then it may be a software issue.
Jan 07, 2015 | Lexmark Prestige Pro805 Wireless...
Lexmark 5400 communication
Have your printer OFF while you turn on your computer, and only after the computer comes on, then connect the printer cable. That's what I do.
Jan 24, 2009 | Lexmark X5470 All-In-One InkJet Printer
Loading Software
install the printer driver first (do not connect the printer yet until installation procedure asks you to connect the printer)
then set it as your primary printer
Nov 04, 2008 | Dell Inkjet 720 Printer
My printer is not communicating with my computer. I just got a new computer and I have tried restarting my computer and unplugging the usb but nothing works. I need to know what i can do to get my printer...
as it is a new computer, have you tried uninstalling the printer software and start again. install the software as you did the very first time, this may clear any incompatible issues you may be having. remember to use the uninstall program which should in the same folder as the printer program (usually C://Program files) and then look for the lexmark folder. once you have fully uninstalled, reinstall. alternatively, insert your install disc that came with printer, select set up and you may be offered options of Modify, Repair or Uninstall.
hope this helps
Sep 21, 2008 | Lexmark Office Equipment & Supplies
Lexmark 1240...
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Aug 10, 2008 | Lexmark Optra Color 1200 Led Printer
Computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.,6959,204816596_652569481_0_en,00.html
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark Printer Install - No Communication Error
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
