Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Vacuum plugged in but not on, smoke started coming from the motor
My rainbow vacuum cleaner was plugged in but was off. Smoke started coming from the motor, and it caused my fuse to electrical breaker to flip off. Now the vacuum won't come on. Any ideas how this could happen when off, and what is the most likely problem with the vacuum.
    Scholar:
  • 39 Answers
The motor winding burned out. Perhaps the motor was very hot when the vac was turned off after the last use and the insulation of the motor windings broke down when the air stopped moving thought the unit. Perhaps also the polarity of the receptacle it was plugged into is reversed or the plug on the vacuum is not polarized. Those things in combination could cause this but this is kind of a long shot guess. In any case the blower motor is likely burned out and will need to be replaced and checked out.
Posted on Jan 18, 2009
How do I replace the fuse on a rainbow vaccum?
The D4 model Rainbow has a Thermal Cut Off
This has to be manually replaced. It is attached to the Field 120v D4
If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
You can also speak with our technical support team Contact Us
RainVac
Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
My rainbow was working, now the rug cleaner quit.
Does your power nozzle have a red power light? Your Circuit Breaker PN2E PN2 could be defective. Also check the hose connection to the front of the Rainbow. Be sure that it has both latches secure. This can cause power nozzle to not run.
You can also contact our technical support team at Contact Us
RainVac
Sep 16, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Theres smoke coming from the motor of the eureka pet pal bagless vacuum cleaner.. i dont know what to do
Some vacs have two belts. Is urs also self powered? If so, has a separate belt. With model # can give better info.
Nov 26, 2014 | Eureka Pet Pal Bagless Vacuum
Vacuum will not come on even though power switch is on.
Rainbows draw a lot of power. It may have tripped the circuit breaker for the receptacle you have it plugged into. first make sure the receptacle is ok, especially if it is plugged into a ground fault receptacle. . Next, unplug the vacuum, take off the tank and see if you can spin the impeller by hand. If you can spin it, the motor is free. If plugged into a good receptacle and the power cord is not cut or broken and still does not run then the motor is bad. it could be the brushes in the motor(which can be replaced), or the armature is shorted out, meaning you need to replace the motor.
Jan 17, 2011 | Rainbow E series Canister Wet/Dry Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I want to take apart and clean my D4C Rainbow and my E series 1 speed, I bought both of them on Ebay, and both have odors,( They are suppose to be the vacuum that cleans and purifies the air) that leaves...
Sorry, but a Rainbow D4 has no filtration at all. The E series has a HEPA filter that needs replacing. You can put liquid Lysol in the water on the D4 and that will help
Apr 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
172 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
