Question about Toshiba 55H70 55" Rear Projection Television
No picture Had convergence issues about 3 months ago all went smooth replacing chips, then about 2 weeks ago , set intermittently had to warm up (about 5 min.) before you would get a picture , now warming up doesn't help at all and have sound but no picture .set is only about 6 yrs old.
  • 41 Answers
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Posted on Jun 29, 2007
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
53udx10b hitachi rear projection big screen. replaced convergence chips 2 months ago. Worked awesome. Started having power issues 3 weeks ago. Turn on - kicks right back off. Used to be able to turn...
Sounds like the problem started out with an intermittent solder connection possibly on the deflection PWB unless the power relay has a bad connection or is breaking down under load. If it is not the power relay, I would check the connections under the deflection board - paying close attention to the area from T701 and T752 including the Horizontal output Transistor for a short. You also have a possibility of defective filter capacitors causing the problem as well.
Jan 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Oct 19, 2009 | Panasonic Televison & Video
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
May 24, 2009 | Philips 43PP9202 43" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
No picture but have sound
Toshiba 57H81 57 in. Rear Projection Television Go to above under solution for tip on fixing your problem.
Jun 22, 2007 | Toshiba TP50H50 50" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
