Question about Samsung Refrigerators
I have a SAMSUNG RS21DAMS and changed the water filter. However, the icemaker is doing very large cubes. How to adjust the level of the water in the ice tray? Where is the screw that regulates the flow of water?
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
  • 883 Answers
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
Posted on Sep 17, 2007
SOURCE: small ice cubes
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Posted on Nov 03, 2007
dcp2
  • 63 Answers
SOURCE: HOW TO ADJUST WATER LEVEL IN ICE MAKING TRAY
Your water pressure is too low. If you live in an area with low water pressure you would have to get a booster pump for you frig. Otherwise you can check the supply line and make sure it has no kinks in it. according to the manufacturer the small ice cubes will not effect the performance of your frig
Posted on Jan 28, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
Ice maker leaks water
  1. make sure the machine is level by adjusting the feet or rollers.
  2. make sure the icemaker is level in the cabinet and tightened firmly.
  3. verify the water delivery tube is in the correct position to deliver water into the cube trough.
  4. IF it still leaks watch this U-Tube video and apply it to your machine. https://www.youtube.com/watch?v=VD5euYbNUPA
  5. I would add a small, in-line water filter to the system supply before finalizing the repair
In Line Icemaker and Refrigerator Water Filter
Sep 14, 2015 | Hotpoint Refrigerators
I have A GE Profile frige (PFSS9PKYASS) with a Samsung ice maker (DA97-07365A). After replacing the water filter, the ice maker made very very large cubes and now will not work automatically. It will work...
Good day!!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
Hope this information will be helpful..
Thanks for using fixya...
Aug 29, 2011 | GE Refrigerators
Kenmore side by side icemaker bin on door, 6mths old, water is only filling part of the ice maker and those cubes are not very large, also changed water filter in Nov and red light is on again to change...
Concur with the water valve solenoid; have had this experience several times with two way and even three way valves. Pull the unit and remove the mixing solenoid after the water is shut off. Sometimes a simple good cleaning and reassembly can make a difference but a replacement is the best answer. Your water dispersion is timed by the solenoid to fill the icemaker. Ergo, the water being dispensed at both ice AND drinking should flow at 1 ounce per second, optimally. The filter issue could indicate the presence of hard water debris already in the system and you'll need to trace that all the way back to the plumbing valve. If it's a needle tap, remove it and plumb in a good valve, I hate those things.
Jan 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
U-line water level too full
If you have a icemaker then remove the cover. You will see a screw with a spring around it. Turn that clockwise like your tightening it this will reduce the size of the cube. Also make sure it is leveled. And make sure no corrosion is around the gears on that same plate. This could make the motor run slower and more water comes into it.
Jun 27, 2009 | U-Line Icemaker
Adjustment screw on side of Maytag icemaker???
No. That setting changes the size of the cube.
Jan 20, 2009 | Refrigerators
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Jan 24, 2008 | Refrigerators
Small ice cubes The ice maker is not supplying enough water. The result is very small ice cubes. The water supply pressure is on max, can there be a way to adjust the water level? The tray is not even...
Oct 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
