Question about Sony DVP-CX860 Multi-disc DVD Player
Sony DVP CX860 300 disc just keeps rotating the carousel
Never loads a disc and will not open the door so I can remove my 300 disc. Have tried plugging and unplugging but keeps rotating the carousel. Any ideas? Thanks in advance.
  • kjbkjkk Apr 12, 2009
    My DVP CX860 keeps rotating, too. But if I select a Medium from position 30, I can change to 31 and than to 32 , the player is working. If I start playing with ex. 222 the carusel keeps rotating, than litle bit left than right, but didnot found the DVD. Stupid , I believe it a garbage SONY part. Never buy stuff from this manufactor. Because no Support, no answer on emails.
  • 130 Answers
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Posted on Apr 15, 2009
Sony 5-disk carousel player will not open. Model DVP-NC685V.
Disc loading mechanism fault. Might be due to a broken loading belt, or broken gear wheel/s. You have to take the mechanism out from the device for repair, and it is somewhat skilled work. Contact any service technician to get this set repaired. If you wish to get some details; visit the site linked here. Pull up older posts.
Jan 10, 2017 | Sony Televison & Video
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
Disc is stuck on playhead, won't come out on carousel.
No way but to open the cover the mechanism and remove from the drive of the mechanism.
If the power is present, then check the loading motor drive mechanism , checkthe drive IC for fault.
If not check the power from the SMPS and rectify.
If not the board can be faulty.
Sep 25, 2010 | Sony DVP-NC85H Multi-disc DVD Player
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
CD player does not rotate
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Feb 10, 2009 | Sony CDP-CX235 200-Disc CD Changer
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Moved CD changer with discs inside - won't "reset" / work
Mar 27, 2007 | Sony CDP-CX400 400-Disc CD Changer
Sony DVP-CX860 Multi-disc DVD Player Logo
509 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
