Question about LG HT503TH Theater System
Lg dvd receiver ht503 wont play any dvd properly
The picture from any dvd is jumpy or just hangs. the audio is out of sync with the picture, also scratchy sounding. dvd receiver is connected to an LG full hd plasma via HDMI and optical digital cables.
5 Suggested Answers
SOURCE: LG LFD790 installed with cable
TV CONTROLLS LFD790
Posted on Jun 18, 2008
SOURCE: I have a LG 42
I have an almost exact set-up and you will only get sound out of your rear speakers when the TV channel is broadcasting in 5.1 Ch Stereo. Otherwise the sound is limited to your front, center, and woofer speakers.
Posted on Sep 28, 2010
  • 334 Answers
SOURCE: I have an LG DVD
It would appear from what you have said that you have everything connected properly. Maybe a silly question, but make sure you select the digital input on your LG to get the sound from the PS3. If there is still no joy, unplug the optical from the back of the LG unit. Look at the end of the Optical cable that should still be connected to the ps3. Is there what looks light a red light there? if so it means that the optical is getting to the LG system and the LG sytem's digital in port is Duff. If there is no "Red Light", unplug it from the PS3 and look directly at the optical out port on the ps3. Is there a Red Light there? if there is, you need a new optical cable. If there is no red light, you need to enable the digial output on the ps3. If you have and it's still not "red". the optical port is duff.
Posted on Jan 07, 2011
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Audio out of sync
Not much information is provided but generally speaking a sync problem when playing back is not a problem with the amp but a problem with the source file, especially if you are playing a downloaded file. If you are playing a DVD this should not happen. If it is happening with a DVD, please provide further information.
Cheers, Don.
Dec 08, 2013 | Denon AVR-1804 Receiver
How to replace the old faulty dvd drive in an lg ht503
This site has the parts in the UK. http://www.chsinteractive.co.uk/manufacturer_replacement_parts/lg/HT503TH/
Once you have the part you'll have to disassemble the receiver and replace the drive. Small phillips screw driver and patience.
Sep 10, 2013 | LG Televison & Video
Lg ht503
The Manual for your LG DVD Home Ent unit says: Some DVD+/-RW, DVD+/-R or CDRW, CD-R cannot be played on this unit due to the recording quality or physical condition of the disc, or the characteristics of the recording device and authoring software" So If what you burn on your PC can be played on another stand alone DVD Player Recorder than I would say that the problem is just that, not compatible media. Codecs, Firmware Update, Recording software used and Region Code can play part in problems, just depends on how much you can eliminate yourself.
Apr 27, 2013 | Computers & Internet
Only x2 of my speakers and sub is working for my lg ht503 digital receiver
do a speaker check if the speakers work change accoustic 5.1 settings until all speakers play if not swap speaker connections to see if speakers are faulty or channels on reciever is blown and replace accordingly
Oct 11, 2010 | LG LHT854 Theater System
Play back is jumpy
Problem may be with your drive or playback software.
Solutions:
1. Copy your media from your DVD disc to your harddisc and then try playing it (not directly from DVD drive). If media plays well, then there can be problem with your drive.
2. If still play back jumps after copying the DVD to your computer, then the problem might be with your system. Download and install VLC media player from the link.This should fix the proper due to codec and playback.
I hope this is helpful in solving your problem.
Thanks
Sep 06, 2010 | LG GGC-H20L DVD-RAM Burner
My lg ht503 wont load any disc, just says that there isnt a disc in the drive when there is.
its always the spindle motor, should read around 9 ohms, if less replace
Jan 26, 2010 | LG HT503TH Theater System
I need to make my LG DVD Receiver HT503 region free
I need step by step instructions how to set up my home cinema LG ht503
May 17, 2009 | LG LST-3510A DVD Player/Receiver
You should find the answer here.
http://www.dvd.reviewer.co.uk/info/multiregion/
May 17, 2009 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Bad graphics
 hi, ur notebook has nvidiaGeForce Go7600 graphics which works quite good with vista......u may have problem with the graphics drivers try to check whether there are updates on toshibas site......or download it through nvidias site.
Feb 10, 2008 | Toshiba Satellite A100-S8111TD Notebook
LG HT503TH Theater System Logo
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
