Question about Sagem Cell Phones
Field 5709 How do I retriece Feild 5709 from Sam my401x. IMEI is 352911010531830
Unlock 5230 nokia
Hai, Once you unlocked your Nokia 5230 cell phone you can use it with us and any other country. If you need unlock code you can visit this site Simpleunlocking.com here you can get the unlock code and unlock your cell phone easily. To get the code you have to mention your mobile brand name,model,which country is locked now,network provider and imei number. Then they send unlock code through email.
Mar 10, 2014 | Sagem my401x Cellular Phone
Unlock codes for Sagem my401x, 358199002315313, sim 3V, D2005, 252427706/my401x
Dear Mr Please try it:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 04, 2012 | Sagem my401x Cellular Phone
On a 83 harley generator there is 2 posts one is a/ armature the other is f/ feild, what wire goes where?
The green wire goes to the Field and the two Tan wires go to the Armature. Make sure that you "polarize' the generator by momentarily arcing the positive battery terminal with the armature terminal of the generator with the generator and regulator on the bike and hooked up before starting the engine.
Good Luck
Steve
Mar 06, 2011 | Harley Davidson XLH 1000 Sportster...
Free unlock code needed for sagem my401x
please unlock my mobile
modle Sagem 401x
Imei: 358199003443486
Sep 17, 2009 | Sagem my401x Cellular Phone
Bypass windows xp login password field
hi,
Press ctrl+Alt+Delete button twice to get "Log on to windows" screen. Now give "administrator" as user name and just Enter without typing password. your will be Logged in now.
Hope this video's would help.
Thanks,
Appreciate to rate as "Fixya"
Apr 23, 2009 | Microsoft Windows XP Professional With...
2001 Jeep wrangler not charging. Alternator has been checked and tests good. Check gauge light on. Alternator not charging power to the field wire from the battery and power to the back alternator on one...
on the field wires ones a posative and one a negative and the single post gets connected to a wire that runs straight to the main fuse box in the engine compartment then is fused to another wire that goes to the battery have that fuse checked it could be your problem as far as the feild wires the positive side only works when you start the vehicle up to engage the field
Apr 13, 2009 | 2001 Jeep Wrangler
My magnet cracked on my jbl sub woofer can it be fixed
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
Mar 24, 2009 | JBL PB12 Subwoofer
Cell Phones Logo
Top Sagem Cell Phones Experts
Computer Repairing
Computer Repairing
Pavel Pranovich
Pavel Pranovich
Are you a Sagem Cell Phone Expert? Answer questions, earn points and help others
