Question about Philips Senseo HD-7810 Coffee Maker
Coffee maker senseo HD7835 does not start
Calc on (red) on led off all the way, does not lit
SOURCE: Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
SOURCE: stuck senseo maker
The locks shut due to a pressure build up in the pod chamber usually caused by a blocked filter in the centre of the pod holder.
The only way to open the unit is to releive the pressure. The pressure will normally reduce over time, the duration being determined by the pressure build up, condition of pod seals and the strength of the blockage.
A quick DIY solution: (small cable tie and screwdriver required)
Un plug the unit from the mains:
Remove the water container and prise open the rear snap fit panel of the unit carefully using a screwdriver to expose the internal workings, the overflow pipe at the top of the cover must be disconnected to gain enough access to work on the unit.
.The small metal boiler in the centre of the unit is used to heat the water for the machine, if the boiler is still hot allow it to cool down sufficiently for work to commence.
The exit pipe at the top of the boiler feeds directly to the pod chamber, if you squeeze this pipe you will feel that it is under pressure. Cut the cable tie connecting the pipe to the boiler (be careful, dont cut the pipe) and remove the pipe to release the pressure, a small ammount of water will be released during the procedure. The lid should open.
Reconnect the pipe to the boiler replace the cable tie, refit the rear cover making sure to push the overflow pipe back on before you snap the cover shut.
Remove the pod holder and clear the blockage blow through the holder in the reverse direction to ensure the filter is clear.
Replace the pod holder and pour a small amount of water on to it. The water should exit through the delivery spouts if the path is clear.
JOB Done.
Posted on Feb 23, 2009
  • 4090 Answers
SOURCE: how do you take apart a senseo coffee maker
2 words! With difficulty
Posted on Aug 17, 2009
SOURCE: senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Posted on Apr 03, 2010
SOURCE: Senseo HD7832 Calc Cleanup
http://www.misc.philips.com/senseo-descaling/us/en/descalingHD7830HD7832HD7842.html
check this out. They have all the info you need to know. :)
Posted on Apr 07, 2010
Descaling problems
Don't run the clean operation. Just put white vinegar/ water, half and half and run as if making coffee. Let it cool and run through about 3 times and this will remove all scaling/buildup.The rune through plain water.
Nov 08, 2013 | Coffee Makers & Espresso Machines
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
I have cleaned my senseo , but the red light still is on. what do i do next?
Do not turn off the machine until all 4 cycles are complete (2 descaling & 2 rinsing ). The machine will then switch itself off. This is not properly explained in the instruction booklet.
Aug 25, 2011 | Philips Senseo HD-7810 Coffee Maker
Senseo coffee maker
Apr 03, 2010 | Philips Senseo HD-7810 Coffee Maker
How do you 'Calc Clean'?
Hello shid9
This is an easy fix. To decalcify your unit you need to make a water/vinegar solution. 2 parts water and 1 part vinegar. You might need to run two pots of the solution through if the first one is very cloudy. When done with that, rinse with 1 pot of fresh water. This should help remedy your calc problem. I hope this is helpful for you.
Happy brewing! NormanZ
Jul 15, 2009 | Philips Senseo HD7832 Coffee Maker
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Hello, I have a Senseo HD7842/00 (Alu) coffee machine, which still physically works, but for some reason none of the lights come on any more. The small LCD screen is no longer back lit (used to light up...
Connections on circuit board are no good.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 26, 2008 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
21 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
