Question about Samsung TXE2746 27" TV
Picture tube How much does a picture tube cost for a Samsung TXE2746 tv? Is this something I can repair myself?
  • 189 Answers
HELLO
If your tube has gone and you are looking to replace it - my advice is don't bother - it will cost you dear in the end. The best thing to do is try to get another CRT TV set (maybe a different make/model).
It is a skilled job replacing a TV tube and should not be attempted by anyone who does not know what they are doing!!! In the wrong hands a CRT is dangerous and could cause serious injury if dropped or handled incorrectly (it makes one hell of a bang).
I wish you luck with it all the same (:-)
Posted on Sep 22, 2009
Bought a samsung 42' 4000 series tv, its less than 2 years old & the picture went bad looks worse than a really old tube tv watching an old VHS. contacted samsung-they don't care, referred me to a tv...
Why won't the Samsung Authorised Dealer repair the board? It's not that difficult!
There will be a power fault and the picture is not "building" properly. At worst it will be one of the memory chips.
With a reflo soldering machine, no problem.
Jan 22, 2011 | Samsung LN-S4041D 40 in. LCD HDTV
Plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
Jan 07, 2010 | Samsung TXE2746 27" TV
Where can i find a replacement picture tube for my akai 42" LCD tv?
Due to residual electricity, replacing a TV's picture tube is very dangerous. I would NOT do it myself. Besides this, getting a new picture tube frequently costs almost as much as a new TV would.
You can contact a local repairman (if it's still under warranty just send it back), and get an estimate, but seriously consider getting a new TV.
Sep 19, 2009 | Akai LCT4216 42 in. LCD Television
Samsung CRT HDTV - Color Problem - Red, Blue, No Green
This will be a lack of green drive caused either by the green output transistor having failed or no green output from the driver IC. As to which you have depends on how old the TV is. These are located on the CRT base (square type board connected to the neck of the CRT. You would need a multimeter to check the voltages going to the green output on the crt. It is also very possible the CRT is internally faulty giving no green, if this is so, you will need the crt (tube) to be replaced,it is not very economical to do this now a days.
Jul 06, 2009 | Samsung Televison & Video
Samsung CRT HDTV - Red, Blue, but No Green.
If their is no green chances are the chip for RGB on the tubebase has packed up its usually something like a TDA 6107Q
Jul 06, 2009 | Samsung TXJ3676 36" TV
The A76JTS90X11 screen is a thin horizontal line. I had this repaired before, but the cost to have a service repair is high and the cost of new TV's are decreasing, so I wanted to try to repair myself. The...
The vertical IC either has bad connections or is defective. This is a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837, TAxxxx or something similar. If you can solder, you should be able to fix this yourself. Please note that there are potentially dngerous high voltages present even with the set unplugged. Try resoldering the pins of the IC first. If that failes to resolve the problem, replace the IC. Dan
Jun 09, 2009 | Toshiba Televison & Video
Dull / dark screen and picture quality not sharp
The cooling fluid in the blue and perhaps the green picture tube assembly has become contaminated. Only solution is to remove the assembly and dump old fluid and clean and reinstall new fluid.
Apr 30, 2009 | Televison & Video
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
Have to turn tv on and off to get picture
You seem to have tuner problem. has been a problem with the older model Samsung.
Nov 05, 2008 | Samsung TXE2746 27" TV
Magnavox tube TV - No Picture
If you see any image at all on the screen then it is not the tube. Could be an issue with the tuner or video output of set.
Jun 20, 2017 | Televison & Video
Televison & Video Logo
185 people viewed this question
Jerry Greenberg
Jerry Greenberg
