Question about VinoTemp VT24-G 24 Bottle Wine Cooler
VT12TEDS display black, clicking sound in back panel, tic, tic, with a blinking light diode, but no fuse seen, nothing moving, maybe at times the fan blades want to move but do not, they spin freely by hand, plug and unplug/ playing with front display temp controls makes no difference. Lost User Manual. Is there a way to reset something? Power outages in Hawaii are common, and power surges and brown outs also common. Guido.
  • sgorders Feb 15, 2009
    Yep....exact same problem. You described it well.
  • wolverine95 Apr 19, 2009
    Exactly the same issue. No solutions?
  • 5 Answers
My VT-12TEDi stopped working after about six months; the common ticking sound from the controller board. After a little research, I found the 16V 1000uF 16mmx10mm capacitor (silver and black can) on the board (upper left corner) was bad. Visual indications are the typical "popped" top of the capacitor can. I purchased a quality replacement capacitor for less than $1 and replaced it. It was a very easy soldiering job that most people with a pencil iron could do. The unit works great now and I don't expect it to go out again anytime soon.
Posted on Mar 17, 2011
  • Jojo_Johnson Jun 22, 2011
    Just fixed a broken VT-12TED using this - pulled out the control board in the back, located the bulging capacitor (1000uF 16v) in the upper left corner, desoldered it using some solder wick, plopped in a much beefier replacement (1000mfd 50v), soldered, reassembled, and it's working great now. Total cost - about $3. Total time - about 15 minutes plus the trip to Frys to get the part.
  • EELBOY Aug 11, 2011
    Jojo you get a huge gold star!! Went to Radio Shack and bought a new capacitor for $1.97. Had it installed and everything buttoned back up in 15 minutes. Plugged it in and everthing works!!
    Thank you, thank you , thank you!!!
  • 59 Answers
Your control panel is bad. The best way to fix this model is to go to ebay and get a replacement. If you order the board from the factory, you have to soldier wires. If you order the setup off ebay, you do not have to soldier anything and it is just a swap out. cost about $49. Good luck
Posted on Mar 15, 2010
Tv turns on but no picture or sound, power light blinking
How many blinks does the light do? Or is it constant?
Jun 16, 2007 | Toshiba 27DF46 27" TV
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
May 15, 2009 | LG L1915S 19" LCD Monitor
Sony grand vega 55" will blink green for three times than red blinking under the power light. nothing comes on no sound, no picture and no fan's are running. Tried to change the bulb, power board...
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
May 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
No picture or sounds red light blinks 10 times
The parts you need are two diodes, D6301, D6309, and D6116, Sony part numbers 6-500-567-21 (D6301 and 09) and 8-719-081-97 (D6116), they are located on the G board, and that's located on the left side of the set, as seen from the back.
D6116 is connected to pin 9 of transformer T6101, and D6301 and 09 are in series off of pin 7 of that transformer.
May 05, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony 32XBR400 Wont Power On
I do not believe the set is too far gone. The standby light blinks codes up to 7. If the standby light blinks more than 7 times it usually means that there is a short on the clock or data line. There are several small zener diodes connected to the clock and data lines in a couple of different places on the main board. Many times I have seen one of the zener diodes become very leaky, usually along the back of the board, loading down the clock or data line which produces the symptoms you are seeing. If you have no experience locating shorted zener diodes and unsoldering and soldering small parts, allow a qualified tech to service the set for you.
Aug 27, 2007 | Sony KV-36XBR400 36" TV
Furniture Logo
879 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
Level 1 Expert
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
