Question about Karcher K2.26 Electric Power Washer
Motor runs constantly with low pressure.
Unti is out of warranty and from the manual lists part no. 1.423-954.0
Immediately when plugged in to power and after the ''RESET'' on GFCI is pressed the motor turns on. This is regardless of the power switch being ''OFF'' or ''ON'' on the side of the unit OR regardless if the gun trigger is being pulled. When the power switch is ''ON'' and trigger is pulled, the pressure from the nozzle is less than 50% of normal.
I remember the unit wouldn't make a noise until the switch was turned to ON. And only then, it would run a very quick pressurizing cycle and then shut off until the trigger was pressed.
I found a 90850340 K-Switch from an online parts store but not sure if this is the cause of the issue or not. I have completely taken off the housing and taken a look into the electrical housing box but I'm at a loss for what the crux of the issue is. Please help!
  • 2,176 Answers
What you described I would think that it a switch problem, I would go to Karcher.com and order an original part for this and start over with the electrical portion and then go from there.
Posted on Jan 23, 2009
Where is the reset button located?
The manual for your sprayer list several possible causes of the motor not starting, but does not indicate the presence of a reset switch. It has Thermal Overload but is reset by simply letting the motor cool.
From the manua: lProblem
A.
The unit will not run.
Troubleshooting cause
1.
The unit is not plugged in.
2.
Tripped breaker.
3.
The pressure is set too low (pressure
control knob set at minimum setting does
not supply power to unit).
4.
Faulty or loose wiring.
5.
Excessive motor temperature.
6.
ON/OFF switch is defective
Hope this helps!
Dec 05, 2015 | Titan Impact 1140 High Rider Airless Paint...
Oil light on while running
Normally, the oil light indicates low oil pressure, usually due to lowe oil level. That being said, is you have a constant oil light with the engine running and you are not getting clacking noises from the valves, you may have a defective oil sender. Regardless, it is not worth destroying the engine to find out. You should immediately shut the engine and check the oil level. If it is very low, add oil and retest. If the fault persists, attach a mechanical oil pressure gauge to the engine. If the pressure is normal (usually 30-45 psi), then change the oil pressure sensor. If the oil pressure is less that 20 psi, you should investigate the oil sump and pump for problems.
Oct 04, 2015 | Cars & Trucks
Why does my nuvi reboot constantly when i plug in the power cord?
It is likely causing a spike in voltage and thus the system senses an error and makes it reboot. If it is under warranty return it.
Aug 28, 2014 | Garmin NUVI1390T Nuvi 1390t gps
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
Pump runs and runs
You can take the cover off the switch and turn the small nut counterclockwise to lower your high setting, as turning the large one, will change both high and low settings, and this may take care of your problem for now. If you have a indoor pump, the pump may be worn and having a hard time getting up to pressure, or a foot valve plugging up, or small hole in the pipe going into well.
Jan 04, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
Have a Rinnai thru-the-wall 1001f. Has run flawlessly for over 15 years until now. When the heater runs, it runs fine. But we find the heater is turning itself off more and more lately. On the front panel...
I had the same very exact problem and got my hands on the service manual for the Rinnai 1001 series heater to solve it. As fas as the spark gap it should be 3mm but I went through a lot of tests of the components and found that Solenoid 1 coil was open. It should read about 1.3K and mine was completely open. Solenoid 1 is the one against the back cover. You'll need a small inspection mirror to see it but it is part number C23B-23. REMOVE POWER/UNPLUG FROM THE WALL FIRST then pull the plugs off all of them and check the resistance of the coils, they all should be about 1.2-1.3K. If you havent already found the answer I hope this helps.
Also check the pressure switch, bottom right side in the front. Its a disk, diaphram type device about 4 inches in diameter with a microswitch on it. That switch should close, zero to 1 volts across it, once the combustion fan starts up and builds a little pressure. If it doesnt it could be the switch or the intake or exhaust parts of the flue or filters are clogged.
Jan 16, 2011 | Heating & Cooling
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
Karcher K2.26 Electric Power Washer Logo
420 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
