Question about Concord Camera Eye-Q 4060AF Digital Camera
Quality of pictures, camera does not focus
My camera does not seem to focus and I cannot take pictures close up. Even when I push the button halfway down, it still does not focus. Pictures come out poor quality and not clear at all.
Try using macro
Posted on Sep 30, 2007
    Genius:
  • 2,985 Answers
Has this has a knock or been dropped? Whether it is fixed lens or motor Zoom only such treatment would make the lens shift out of the focal plane Try technical support of the makers website. If it is failry new there may be an exchange option.
Posted on Jun 22, 2007
On my 5800 xpressmusic the camera quality is not good. even i checked the quality on 5233 which has a 2MP camera...pictures are much clear than my phone.. please suggest
I have Nokia 5800 as well, but camera quality is good so far. Check your camera setting. Open Camera > Option > Setting > Click Photo quality > Drag the quality level to 3M - High > OK/Choose > Back to camera. Try to capture a picture and see if your problem get solved. And don't forget to click twice on capture button. First one is half push (like in digital camera) rather long until you get green box in the screen means the focus is ready, then push harder to take a picture.
Hope this help and if this helpful RATE please.
Feb 02, 2011 | Nokia 5800 XpressMusic Smartphone
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
My Canon Powershot SD1000 will not focus
You must need to reset all function of auto- focus setting.. its called as master reset. then see its works...
Jun 29, 2017 | Canon PowerShot SD1000 Digital Camera
Takes a long time to focus / take a picture
According to your description, I would like to assume that your camera takes 9 seconds to get the flash ready, not to focus. If it is the focus problem, you need to send the camera for realignment or to replace the lens.
Here is my suggestion:
Try to disable the flash. Does it still take 9 seconds to take picture? If the answer is ‘no’, then try to use fully charged batteries or new batteries to reduce the flash charging time.
If you have a ‘batteries drain quickly’ issue as well, this tip may help: Why my camera keeps saying ‘change battery’ even with new batteries?
Jul 01, 2009 | Canon PowerShot S5 IS Digital Camera
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 | Cameras
Focusing problems
You may be beyond (up to close) the focal capability of the lens. Even though there is a macro setting, the lens may not have the capability to focus on an object that close (without adding an external macro lens). The specification on the minimal distance for focus should be listed in the owner's manual.
Mar 04, 2008 | Olympus SP-350 Digital Camera
E10 can't focus in dark places
The focus mechanizm does nee to 'see' what it is looking at. Check you manual see if there is a setting for fixing the focus so thatr the camara can shoot from near- about 2m to infinity without the focus operating.
May 08, 2007 | Pentax Optio E10 Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Focus
If the camera is having a difficult time auto-focusing you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Concord Camera Eye-Q 4060AF Digital Camera Logo
Top Concord Cameras Experts
Michael Galve
Michael Galve
Are you a Concord Camera Expert? Answer questions, earn points and help others
