Question about Panasonic Cameras
Panasonic DMC TZ6 blurred out of focus pictures
Out of focus pictures
SOURCE: Dropped Panasonic DMC-FX07
There is a small gear that needs to be replaced. It's about 4mm in diameter and about 10mm long. The teeth can be broken off when the camera is dropped on it's extended lens housing.
I'm trying to find the part number right now, but have not had any luck. If anyone can help, please post the part number and dealer site...
Posted on Jun 12, 2009
fikretunalir
  • 238 Answers
SOURCE: cannot find my driver for my lumix dmc-tz6
This is your Panasonic Lumix DMC-TZ6 Driver.
Posted on Feb 28, 2010
  • 13 Answers
SOURCE: My Panasonic Lumix® DMC-ZS3 will not focus
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
Posted on May 31, 2010
lock123
  • 6831 Answers
SOURCE: my panasonic lumix DMC-FS15 won't
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 10, 2010
ZJLimited
  • 17970 Answers
SOURCE: Panasonic Lumix DMC-FH20 shows "SYSTEM ERROR
Sounds like the Focus and Optical Image Stabilization drive motors are bound or broken. To fix this wrong will need disasemble the lens unit, focousing unit to do service; if needs, replace the damaged parts and assemble to run normally. Don't do this if your camera is under warranty.
Or, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well you know, Panasonic will normaly repair or replace it as long as it is due to manufacture defect.
Hope this helps.
Posted on Jun 22, 2011
How do i set my tz6 to 300 dpi
DPI (dots per inch) is an output parameter and is irrelevant to the camera.
Let's say you took a picture and want to make some prints of it. You make a 4x6 print and a 8x12 print. Those will be printed at different DPI settings but It's exactly the same file from the camera, just printed at different sizes. The camera can't know what size prints you might make from the picture, so it simply puts in a default value.
If you really want to change the DPI setting as recorded in the file, you need to do it on a computer using a photo editing program.
May 07, 2014 | Panasonic DMC-ZS1 / DMC-TZ6 Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
My focus keeps blurring for a while and then for no apparent reason corrects its self
This is called focus pumping, and can occur. Nothing to worry about. If the camera has enough light or there is lots of contrast in the object you want to take a picture of, it will be less. The correct focus is found quicker.
Every camera in autofocus, needs to find the correct focus. Only the bigger and expensive DSLR's, will focus a little faster then the compact camera's. Still Every digital camera has this effect, although not every on is as observing as you I think.
Only when it takes several seconds every time you want to take a picture, it could be an error. But when it was on focus and you want to shoot a second picture from the same situation, and is is quick in focus again. Your camera is ok.
Nov 29, 2013 | Panasonic Lumix DMC-FZ8 Digital Camera
Shutter/iris won't open on powering up
This is a mechanical problem and would need to be looked at. Please click on the link below for assistance.
Click Here
Oct 03, 2013 | Panasonic DMC-ZS1 / DMC-TZ6 Digital Camera
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Blurry Pictures
Check that you have not got Macro set accidently.
If lighting level are low and the camera is selectinging a slow speed - reset to Apeture Priority -setting 'A' and and be very gentle with the release - the slightest movement will blur an image on long exposure.
Try these thing and if still introuble come back with more detail
Nov 11, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Blurred background
In general, a digicam like the fz15 uses such small lenses (true focal length, not 35mm equivalent) and sensors that they have greater depth of field than a DSLR will have. The only way to really reduce it is to use f/2.8 and full zoom. Also it's reduced the closer the subject is to the lens.
Sep 07, 2005 | Panasonic Lumix DMC-FZ15 Digital Camera
Cameras Logo
43 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
