Question about Sony Cyber-shot® DSC-W120 Digital Camera
DSC-W120 Sony. Movie record time frame
I cant get it to record longer than 10 minutes. How do I make it record until batteries die? Its all charged and my card permits over 3+ hours.
  • 32 Answers
I'm afraid that Sony did not think that this was an important feature. The camera is inherently limited to ~10 minutes. There's nothing you can do to make this happen. See this page from Sony (it's a google cached version because the actual Sony page was down when I checked). Scroll down to where it says "MPEG Movie VX Fine Mode"
Posted on Jan 18, 2009
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Dead battery 1990 xlh sportster 1200
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Chaging batter
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
I charged my 2GB SENSEI mp3 player for more than 4 hrs...but still its not working even for 10 to 15 mins......so wat is d time required for full charging....
Depending on the age of the mp3 player, the battery may be shot and you may need a new one. mp3 players tend to get heavy usage and the batteries can die and get burnt out quickly especially if they are not charged properly. Try draining the battery until it can no longer turn on. Then charge your battery for 6 hours. Good luck.
Mar 01, 2011 | Computers & Internet
My LG VuCU920's battery is dieng quickly.
yes this is a battery problem that happend to my phone . it means you need to get a new battery and it will start working like normal
Jan 22, 2010 | LG Vu CU920 Cellular Phone
I put my camcorder to charge, but it won't charge at all
If this is happening with your new battery, your charger is possibly defective and improperly charging. I suggest trying a new charger!! Hopefully this helps,,please rate thanks!!
Aug 05, 2009 | Video Cameras
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Video camera jazz dv179 how many hours need to charge
I HAVE THE SOLUTION!!!!! the camera comes with a charger that plugs into the wall and into the usb port on the camera
Oct 27, 2007 | Jazz DV-179 Digital Camera
Sony Cyber-shot® DSC-W120 Digital Camera Logo
137 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
