Question about SiPix Pocket Printer Thermal
Sipix A6 Din 8 to serial Schema
Does any body have a schema for Sipix a6 cable Din 8 to serial? i lost my cable, and i cannot buy it in my place, Unfortunately i works in island with less than 14Kbps internet connection, even i cant found any PC store here. but i really need it, at least i can build the DIY cable for sipix A6
5 Suggested Answers
SOURCE: SiPix Pocket A6 Printer Windows Vista Driver.
SiPix never had a Vista driver. Most new computers, like mine, do not have serial ports. Here is how I got my A6 working with Vista --
1. Purchase a serial to USB converter cable. (I got mine on Ebay for about $4.00.) Plug one end into the serial cable that came with the A6 and the other end into a USB port on the computer. Vista automatically picked up and installed the converter cable. In Device Manager, it shows up under Ports and gives it a com port number. Right click on the device and click on Properties. Click on the Port Settings tab and change Bits Per Second to 115200, Data Bits to 8, Parity to None, Stop Bits to 2, and Flow Control to Hardware per your A6 Owner's Manual. Click OK.
2. Now go to Printers in the Control Panel. Click to add a printer. Follow on screen prompts. Whe asked what port the printer is on, highlight whatever port the USB converter cable was assigned to. (In my case, Com 4.) When asked for the driver, direct it to the CD Drive where you have the A6 driver disk. Direct it to the Windows 2000 driver. If you try to use the XP driver, it will tell you it is the wrong OS. The 2000 driver will install. Your A6 should now be installed and show up in your list of printers.
My A6 now prints from any program or the internet using Windows Vista.
Posted on Mar 23, 2009
kirkx
  • 2019 Answers
SOURCE: sipix pocket printer a6 window 7 driver
Windows 7 should be able to use Vista or XP drivers, but you should have no trouble downloading Win7 drivers:
http://www.driver-fix.com/driverdetective.php?t=Pocket%20Printer%20A6%20Drivers
Posted on Jan 17, 2010
  • 425 Answers
SOURCE: i require a driver for
The instruction manual says you can download the latest drivers from support pages on the SiPix and IS/Complete sites. When I checked, neither site had these up.
Good luck try uninstalling the software then reinstalling you will have to go control panel and use uninstall.
Hope this helps these printers are great when you can get them to work a little slow but handy,
Chris Thrash
B52Computers
Posted on Jan 20, 2011
64 bit Windows 7 and the SiPix Pocket Printer A6...any solutions?
I have one of these printers. If you have the 32 BIT VERSION of vista, or 7 this printer will work via the serial RS232 port using the windows 2000 driver.
This driver does not work with the 64 bit versions of these operating systems. I don't know of any driver for 64 bit systems.
32 bit versions of Ubuntu do have a driver for this printer as of the 2016 version.
the Sipix A6 pocket printer uses these settings on the com port:
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
I hope this info helps out.
Jan 08, 2011 | SiPix Pocket Printer Thermal
Hey! I recently bought SiPix A6. It works almost perfectly as it shuts down everytime when i have printed one page. Same thing on AC or batteries. If i try to remove batteries and reinsert, or remove AC...
I don't have a real solution but I do have that problem. first page prints fine. If I try to print again, the printer shuts off. I'm using a usb to serial adapter and I realized that if I unplug the usb plug then plug it back in, VIOLA it works agail BUT only for 1 more page! After each page, I have to unplug and replug the usb cable from the computer. I definitely think that this is a driver problem and not a power problem. On one laptop it work ok but starts making the above problems when changing paper settings.
I've read on the web about this problem. Does anyone have a solution?
Sep 06, 2010 | SiPix Pocket Printer A6 Mobile Thermal
Sipix pocket printer a6 window 7 driver
Jan 17, 2010 | SiPix Pocket Printer A6 Mobile Thermal
BROTHER MFC8640D A6 ERROR
A6 is a scan failure during a fax, usually means the cis unit is defective and needs to be replaced. The cis is the scan assembly.
Dec 24, 2009 | SiPix Pocket Printer Thermal
I eed to know which port to connect to to use usb
I had this problem as well. I loaded the drivers for the USB to Serial Adapter and the drivers for the SiPix printer, left the adapter cable plugged in and rebooted my pc. After powering my PC back up I went back into the SiPix printer properties and another com port (5) showed up in the list of com ports. This was the port I needed and the printer woks great!! now your comport may be different depending on which USB port you have your SiPix connected to. This worked for me. Hope it helps you out!!
Nov 18, 2009 | SiPix Pocket Printer A6 Mobile Thermal
AUDI A6 RADIO CODE
try another dealer. maybe try to get ahold of one of the techs at lunch time. this info should be free to the car owner, just be ready to supply the title to the car for some proof. maybe try buying the parts guys lunch or coffee and donuts....this usually works for this type of problem. unfortunaley this info really is dealer only..
May 26, 2009 | 2002 Audi A6
I need to change my starter on my Hyundai 1995 Accent I can't see where it is I would need a schema on how to remove a starter on Hyundai 1995 Accent. If you don't have a schema please explain the better...
your starter always going to be somewhere near the flywheel of your vehicle it might be on the bottom or something but just take a look where your batter cables go and alternator cables follow them and they may lead you to the starter
Mar 15, 2009 | Hyundai Motor 1995 Accent
Aug 17, 2008 | SiPix Pocket Printer Thermal
SiPix Pocket Printer Thermal Logo
26 people viewed this question
Top SiPix Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a SiPix Office Equipment and Supply Expert? Answer questions, earn points and help others
