Airwell aircon timer light flashing - Heating & Cooling
5 Suggested Answers
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
hvac1960
  • 2133 Answers
SOURCE: aircon set to cool but
It's thermistor problem. Replace thermistor and run the unit. Hope it's helpful?
Posted on Dec 26, 2010
SOURCE: aircon runs for a few
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Posted on Jul 19, 2011
My fan is not comming on onmy airwell aircon
Supposing you have no experience with electricity you need an electrician.
Either the thermostat is defective (most cases) or your AC has no power (Fuse). So contact an electrician to fix this problem.
Oct 19, 2014 | Heating & Cooling
LG aircon flashes blinking 8 times and the shifts to timer led flashes blinking light 4 times
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Bulance AC Cleaning Repair Services
Apr 23, 2014 | LG Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/chris_e1fb7ef6a5bdb086
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Apr 20, 2014 | LG Heating & Cooling
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
