Question about Technics SL-1200 Turntable
Speed control issue
This is not really a problem but more of a question. How can I modify the 1200 so i can control it's rpm completely. ie so i can run it at any speed between 0rpm and say 100rpm.
I need this for a project I am involved in, any advice would be very much appreciated.
Thanks
James
  • jmullord Jan 20, 2009
    Thanks for replying to my question. You pretty much confirmed the advice given to me by KAB.
    They recommended that I buy a Numark TT 500 as this has a variable pitch control capable of upto 117 RPM straight out of the box.
    James
  • 515 Answers
Not sure I understand what you need done. The 1200 has a pitch control, which allows you to control it's speed. Do you want to disable the 33/45rpm function, and assign that to the pitch control, so instead of controlling pitch, you control the RPM? This will put quite a strain on the drive circuits of this unit, but it can be done. Although, not an easy modification, as you will have to modify multiple resistors and IC's on the main board. This should only be professionally done.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Posted on Jan 20, 2009
I have an 03 Jeep Grand Cherokee v6 2x2 with 170k... I'm having a couple of issues... 1. Occasionally will have trouble with cycling through gears when getting on Hwy causing decreased, sluggish...
I would consider changing the vehicle speed sensor. When they go bad, they can really throw out a lot of bad data to the computer, resulting in unexpected behavior like you're experiencing. They're only around $20-$25. I hope this helps! :)
May 02, 2014 | Cars & Trucks
Idles@2500 rpm until engine warms up
old post
all do, everyone. but. the devil really is in the details with EFI.
this IAC valve does that,
to speed it up warm up , put in a 195F thermostat.
this assumes 800 RPM is hot.
most of these engines, do this. new. bewlow.
1: cold start, for 3 to 15sec, 2500 rpm , worse in alaska.
2: then the above DASH pot closes and IAC takes over, at ~1200
3: then as engine heats the IAC closed inch by micro inch a
its now 100% closed and the ECU not controls idle hot.
using the modulated ISC,
there is a fast idle feature on this year, 950 to1000 rpm hot
with these turned on.
1. headlights hot.
2: defrost glass, rear.
3: heater fan on.
4: a/c on if opted.
other wise 800 is normal hot.
Jan 13, 2014 | 1989 Geo Tracker
Major vacuum leak
A vacuum leak is unlikely to hold RPM that high. 1st inspect throttle plate not closed all the way, possibly hung up, or cable pulled too tight holding throttle open or accelerator pedal not releasing completely. If ok, next would be a computer controlled issue , Possibly idle speed control motor or throttle body assembly if not cable operated .
Dec 31, 2013 | 2001 Dodge Intrepid
I have 1990 ford f150 5.8 liter it idles high when in park and idles about 1200 rpm when in gear and sometimes surges up and down. i have clean the idle control and check showing 12.5 ohms still won&#
One common problem is a vac leak or a sticking throttle plate.
The computer controls idle speed by how much air is allowed into the intake. The idle control valve could be sticking even tho you have cleaned it, or have a faulty motor.
Sep 12, 2012 | 1990 Ford F150
2500 HD chevrolet low idle problem
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 03, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
Runs rich and cuts out at low rpm
Possible leaking injector, bad plug. vacuum leak, ck timing etc.
Feb 01, 2018 | Dodge Ram 250 Cars & Trucks
I have 2006 scion xb and when driving the rpm stays around3500-4000 when running 65 mph can it be modified to run lower rpm
3500 is about normal for an xb at 65 mph. My previous ride was a pickup and rolled at about 2000-2500 on the highway. But the XB's engine is way more "tightly wound". Your rpm gage should run at about half of of your speed...ie: 70 mph will be about 35 (3500) rpm, 80 mph will be about 40 (4000) rpm. Freaked me out when I first got the thing, but after researching it Ive found out that with a stock engine it actually runs more efficient at the higher RPM's. The 06 boxes won't redline until 6000 rpm, so unless you are driving 120 on a frequent basis you're good. You can probably have it modified to run lower, but you will lose the awesome gas mileage and overall it is not going to improve the way it runs, and would have no benefit............
Jan 14, 2010 | 2006 Scion xB
My 2006 fz6 idles at 1120 to 1200 rpm is this the right idle rpm
ironmike_926 wrote: no it should be anywhere from 600 to 900
Absolute rubbish!! The idle speed should be between 1250 and 1350 rpm. If the engine is cold, the EFi will raise the idle speed temporarily to about 1600 rpm until it warms up (usually within 5 to 10 minutes at a standstill).
Your idle speed of 1120 to 1200 rpm is absolutely fine. However, if it drops any lower, you can raise the rpm by playing with the idle speed adjuster screw located on the gear-side under the fuel tank (can be seen without having to remove the fuel tank). Turn clockwise to increase rpm. You will find details on how to do this by selecting your manual from this link:
http://www.yamaha-motor.co.uk/community/service/manuals.jsp
WARNING: if the idle rpm continues to drop, you may have a more serious issue with the valve clearances, air-filter, or spark plugs. Consult a technical book (such as Haynes), or take it to your local Yamaha dealer to get it serviced.
Oct 04, 2009 | Yamaha FZ 600 Motorcycles
Technics SL-1200 Turntable Logo
458 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
