Question about Dynamo MartinLogan Subwoofer Speaker
Where to buy fuse for Martin Logan Dynamo 1000
2 Suggested Answers
SOURCE: I own a used Martin
Did you get the sub fixed? I know someone with the same problem - won't turn on, fuse is fine. May be due to different underlying problem, but wondered if you discovered what it was and if you got it fixed.
Mike
Posted on Oct 29, 2010
I have a Martin Logan Abyss subwoofer. It has a volume control that when touched explodes the volume. How do I fix this?
Actually the most likely answer is that the volume control knob (potentiometer ) needs cleaning internally or replacing
Aug 16, 2017 | The Audio Players & Recorders
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site.
Steven Leckrone
The Service Department
30 Unquowa Hill St
Bridgeport CT 06604
203-331-0671
Steven@theservicedepartmentct.com
www.theservicedepartmentct.com
Nov 14, 2014 | Krell Audio Players & Recorders
How can i connect my dynamo 700 w using martin and logan transmitter to my marantz sr5008
You just need one of these though all the sockets would need to be male:
Jul 06, 2014 | Audio Players & Recorders
I have the 1911 and Martin Logan Motion 10 speakers. Why do I have to turn the volume up so hi to get sound?
are the ohms on the speakers and the receiver rated the same, if not theres the problem
Mar 14, 2011 | Denon Audio Players & Recorders
I own a used Martin Logan Dynamo (older series) and just today found out there is no sound coming out/no led light (at the back) either. I opened up the back and saw the 110V power is getting in but no...
Mike
Aug 28, 2010 | Dynamo MartinLogan Subwoofer Speaker
How do i remove the impeller from a dynamo pool pump ?
WITH LOTS OF LUCK . THEY SCREW OFF(OFF TO THE LEFT LOOKING AT THE IMPELLER SO COUNTER CLOCKWISE ) VICE GRIP OR SCREW DRIVER ON SHAFT TO HOLD IT, THING IS IF THE SHAFT IS RUSTY YOU HAVE A REAL GOOD CHANCE OF BREAKING IT AND IMPELLERS CAN BE HARD TO FIND.. THE SEAL SHOULD BE # 1000 FOR THAT PUMP... BEST OF LUCK.. J
May 25, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1HP -
Bought a used Martin Logan Dynamo subwoofer a couple days ago and have a very loud hum when the ac cord is plugged in, even if the speaker is not connected to an audio source. The "hum" can be heard in any...
Neither the amp or the sub have grounded power cords.
I have discovered the ML Dynamo takes about 30 minutes to switch to standby in auto mode.
With speaker level inputs connected to the Onkyo A807 amp, both units powered from the same wall outlet, Dynamo sub on Auto, the sub hums for about half an hour after the Onkyo is switched off, then the sub goes quiet. Not so good.
I connected a bonding wire between the two units on 3_7_09. If I smoked some old audio gear I could just look at that as an opportunity, right?
Works fine. Now I have the ML powered from the wall and working normally.
Jun 30, 2009 | Dynamo MartinLogan Subwoofer Speaker
Wiring of a Panasonic CQ-C1001N Car CD Player into a Morris 1000
You can get wiring diagrams on line, do a search using the players full name. Is your morris positive on negative earth? you will have to swap it if it is positive as the player is negative earth only (usually dynamo is +ve and alternators are-ve ) I have changed lots over when dynamos were common, turn the battery round and pull the 2 wires off the dynamo take a wire from the +ve battery terminal  and "wipe it across the 2 terminals on the dynamo, this will make it -ve earth too, re connect the dynamo and off you go
Mar 17, 2009 | Panasonic CQ-C1103U CD Player
Loudspeaker Repair or Buy New Replacement?
I have tried the repair thing before. They can be repaired the only problem is they dont seem to hold up as good or for long. I found it better just to replace speekers with new ones
Oct 23, 2008 | Cerwin Vega LS-15 Speaker
Dynamo MartinLogan Subwoofer Speaker Logo
138 people viewed this question
Top Dynamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynamo Audio Player and Recorder Expert? Answer questions, earn points and help others
