Question about Microwave Ovens
I got EMG4753 microwave oven...now 4 yrs old....it's door is not opening when press the door opening lever...pls advice
  • Microwave Ovens Master
  • 9,098 Answers
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety & disassembly info here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Sanyo UK support, parts and authorized servicers here.
Posted on Jan 18, 2009
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
The door press opener button of my kitchenaid
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, usually only the control panel needs to be removed.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Nov 27, 2009 | KitchenAid KCMS185J Microwave Oven
Sharp R1870 microwave door will not open and child lock is not on.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Chances are the rear of the door open button and/or the face of the door open lever is worn enough that it will not actuate properly. Or the lever may be broken.
open.
You can order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Sep 16, 2009 | Sharp R-1870 Convection/Microwave Oven
Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
removed in most cases.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
You can find Panasonic parts in Australia here.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
Door won't open
Chances are the rear of the door button and/or the face of the door open lever is worn enough that it will not actuate properly.
Dec 05, 2008 | Siemens HF17055GB Microwave Oven
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
Microwave is not working
One of the door switches needs to be replace.
Oct 30, 2008 | GE JVM1440 Microwave Oven
Bosch HMT9626GB / HMT9 / 0B 1000 Watts...
Sep 15, 2008 | Bosch HMT9626GB Microwave Oven
R-9H56 microwave convection motor class B
The outer cover will need to be removed to diagnose and repair this. Please unplug the oven first.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
Aug 29, 2008 | Sharp R-510HW Microwave Oven
Door not opening
To order parts, refer to the Sunbeam number in your manual.
Aug 19, 2008 | Sunbeam SBM6500W Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
