Question about APC Back-UPS RS 800VA UPS System
Shuts off and won't charge batteries
Makes clicling sound and powers off. Has new batteries.
    Filmmaker:
    Uploaded 5 video answers.
  • 45 Answers
What does the unit do without the batteries attached? Try re-seating the connections.
Is this the same behavior as before you replaced the batteries? If so, the unit itself has likely failed and will need to be replaced.
Posted on Dec 30, 2012
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
1992 mazda protege dx 4 dr won't start. Battery is only 2 months old. Makes a fast ticking sound from inside car similar to turn signal light out.
Hi Robin, As the battery is new and presumably not defective, I think you should suspect the soloniod fitted to the starter motor. If that component has become defective it will give the sound you're reporting. Depending on where you live in the world and the labour charges, you can have the contacter's replaced or the starter motor (if labour charges are high) Regards John
Jun 30, 2012 | Mazda Protege Cars & Trucks
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
T will indicate charging but it won't charge actor
Apr 23, 2012 | HP Compaq nc6400 Notebook
My starter on my 2000 Suziki quad makes a clicking sound and won't turn the engine over.
Either the starter will have to come out for testing, rebuilding, or replacing, or the battery is not strong enough to power the starter-maybe it's low on charge. Are all your battery and starter connections clean and tight? Verify the condition of your battery before you condemn the starter.
Nov 23, 2011 | Cars & Trucks
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Phone randomly shuts off and battery won't stay charged.
Hi, It sounds like your battery can't hold a charge which is common with rechargeable batteries after a certain amount of time. The only solution to that is to buy a new battery unfortunately.
May 17, 2011 | LG Vu CU920 Cellular Phone
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
APC Back-UPS RS 800VA UPS System Logo
132 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
