Aspire 7220 black screen
Hi all, I have a little strange situation: lcd screen is black durring to POST and windows loading. When Windows is starting all are ok, backlight and LCD work properly. Have somebody any idea about this ? Thank you !
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
Reno7777
  • 3 Answers
SOURCE: ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: acer aspire 5920 series wont load past windows loading bar
OMG ... i was completley distraught. i bought my ACER ASPIRE LAPTOP 6months ago when i was trveling in italy ,im in austarlia. I use it torun my online game ; » www.themafiawarz.eu - and has all my files.
When i got the black screen o death i first am here to the boards finding nothing i was further distraught..
I AM HAPPY TO TELL YOU MY FRIENDS, that i am typing this on my lil baby
Heres what you do....
* you need usb disk drive
* a second computer with internet access (can be work cafe friends place)
* a file you can download from acer or search yourself called ZGIA32.zip
Formatyour drive in fat (*note i tried fat as directed in a number of manualsthough then tried fat32 and it worked then though suggest you try fatfirst *shrug)
open zip file and copy 3309.fd and the fla.exe to the usb stick
rename 3309.fd to ZGIA32.fd
Turn off your laptop making sure that both battery and power supply is plugged in and attach the usb stik/drive.
holddown FN and ESC keys and press the power button, continue to fold FNand ESC keys for 7-10 secs then release - at this point the power lightshould be blinking and you should still have the black screen of death.
press the power button once while its blinking - this will initiate a bios update * DO NOT PUSH ANYTHING AFTER THIS
After 2 mins the aspire should reboot itself , wait for about 7mins if it dosent before rebooting manually
Took me three attempts as i just wasent doing something right though TA DA!!!!!
and i still have my files. yeah team take this and run, hope you havent spent money yet smile.gif
Posted on Mar 19, 2009
romsky79
  • 822 Answers
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
Posted on May 20, 2009
myrlex
  • 674 Answers
SOURCE: Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Posted on Jun 07, 2009
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Acer Aspire 5738 g got black screen
sounds like you need a new screen transformer or new screen or new graphics card - expensive
Mar 21, 2010 | Computers & Internet
Restore to factory default
Most Acer M1640's can be restored to factory settings using the following method:
1. Start with the computer off.
2. Power on the unit, this should cause the Acer POST screen to appear.
3. During the Acer POST screen, press and hold the Alt key on your keyboard, and tap the F10 key on your keyboard.
4.If timed correctly, this should cause the unit to go to a black screen that says "Windows is loading files...".
5. After the "Windows is loading files" screen you should be in Acer e-recovery management. At this point follow the on-screen instructions to restore the unit to factory defaults.
Oct 08, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Free-download of Sound-card+VGA drivers
Please follow the link given below and you will find the driver download for your ''Acer Aspire 7220.''
http://komku.blogspot.com/2009/02/acer-aspire-7220-windows-xp-vista.html
Apr 07, 2009 | Acer Aspire One PC Notebook
Laptop starts to boot then screen goes black
when the windows are going in the booting and it is colored black, the problem can be wrong with the windows or set the mode dual setting LCD 1st graphic assign it, try to use external LCD Monitor or connect to back of laptop
Dec 14, 2008 | Acer Aspire 3680 Laptop
Not loading windows
"a new hardrive" unfortunately looks like a yes. You could try verifying if the HD could be autodetected in the CMOS/BIOS.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Will come on-then say no signal
If you mean the monitor is fine during the Windows booting process and then just as your about to go into Windows goes black then do this...
Start the computer
When the bios screen goes start pressing F8
A Windows Startup screen will appear
If you see the Windows Logo (the loading one) then hit reset and try again
At the Windows Startup page, select Safe Mode and press enter twice.
Windows will now load. Go into Device Manager (Start-Settings-Control Panel-System-Device Manager)
Select the video card, and uninstall it.
Restart Windows
Reinstall your video card using the Installer package (if it's ATI or nVidia)
If this dosn't work, then post back and we will try something else
Apr 16, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
