Question about Kobo eBooks by Kobo
Kobo pegasus android stopped unexpectedly
Application Kobo in process com Kobo books pegasus.android has stopped unexpectedly, please try again
2 Suggested Answers
SOURCE: I purchased two books tonight for my Kobo E-Reader and the money has been taken out of my checking accout. I cannot get the two books to load onto my Kobo. PLEASE HELP.
It may take some time for your deposit to show up in their account ????
Posted on Dec 17, 2011
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo problems
If the books have been loaded from Kobo, you can go to their site and load them again (for free). If not, you would have to get them again from other sources and may have to pay for them again.
Aug 10, 2014 | Kobo Arc
Kobo account login
Aug 10, 2014 | Kobo 6" eReader Touch Edition
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
Dec 27, 2013 | Kobo Arc
After factory reset of my kobo glo, I couldn't get back my books that I ?
First make sure your books are really (still) in your account. Log into Kobobooks.com and check your library. Here's a direct link to the library page: Sign in to Kobo with
If you don't see your books there, you didn't buy them under that user account, or they're been removed from your account. Call Kobo support in either case.
If the books are there, make sure your Kobo eReader is also logged in using the same account. To do that,
1 - Open the menu
2 - Tap Settings
3 - Tap Account
Under 'Signed in as', you should see your user account. If not, tap in Sign in and log in. After that you can sync your library with your Kobobooks.com account from the menu again.
Dec 18, 2013 | Kobo Glo eReader Silver - N613-KBO-S
Where do I find the KOBO desktop
The Kobo eReader is a portable device that lets you read digitized books.
Downloading the eReader is physically impossible.
However, Kobo Desktop is available on the Kobo website.
This application will let you read and buy Kobo eBooks with a computer.
Use the desktop application for transferring purchased eBooks to your eReader.
The download and installation will not take more than two or three minutes.
Open an Internet browser.
Type "kobobooks.com/desktop" in the browser's Address bar, then press the "Enter" key to load the page.
Click the "Download App!" button and the download begins.
Double click the "Kobosetup" file, when the download completes, to launch the Kobo Setup screen.
Click the "Yes" button after the User Account Control dialog box appears.
Click the "Install" button after the Windows Security dialog box appears.
Click the "Next" button after the Kobo Setup installation completes.
Click the "Finish" button to exit the Kobo Setup screen.
http://kobobooks.com/desktop
May 12, 2013 | Computers & Internet
Kobo eBooks by Kobo Logo
141 people viewed this question
Top Kobo Apps Experts
Lesley Cameron
Lesley Cameron
Are you a Kobo App Expert? Answer questions, earn points and help others
