Question about Simmons Mattress Crib 'n More
Bed rails to convert to full size bed
Model # 180080
  • Anonymous Feb 08, 2009
    I purchased the bed at Babies R Us and they do not carry the rails, nor does any of the other simmons retailers in the area. I suppose I will try calling Simmons parts (800) 218-2741 next!?!
  • Anonymous Apr 08, 2009
    WOULD YOU HAVE THE ITEM# SO BABIES RU US CAN FIND IT
We purchased our bed rails through Babies R Us. Be patient, they need to find the right part # through their catalog and this took a couple of days to find, but they finally did find it and we got our rails a couple of weeks later.
Posted on Jan 30, 2009
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Simplicity bed rails to convert to full size bed
we are having the same problem. My husband found this number online that another user said she used. I guess it took her months to find it because with the company being out of business the 800 number that came with the crib isn't working. I've yet to call he just called me with it. the company is out of canada and is said to have the rails or able to get the rails. Its Else Graco, you need your model number and color. 1800-667-8184.
Jan 18, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Looking to convert simmons crib n more item# 180080 into a bed. Do I need a full size double mattress with a boxspring?
yes we still have that just see our site
<a href="http://www.bestmattressreviews.com/simmons-mattress-reviews.html">simmons mattress reviews</a>
Oct 21, 2009 | Simmons Mattress Crib 'n More
I have the ellis deluxe 4-in-1 convertible sleep system how do i convert to full size bed
You need to contact Ellis with your product information to purchase the needed bed rails. The bed rails cost anywhere between $150 -$200 depending on your model.
Aug 28, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at gistecknician@aol.com.
Feb 21, 2009 | Baby Gear
Conversion instructions from crib to full size bed
check this website. www.babysdream.com/Service/AssembIns/pdf/Convertible%20Generation%20Next%20Crib%20Instruction I needed the instruction to convert my daughters bed and was looking for some help and notice your question.
Good Luck
Dec 27, 2008 | Babys Dream Generation Next Crib
Parts Source
Full-Size Wood Bed Rails
Model: 180080
Dec 15, 2007 | Simmons Mattress Crib 'n More
Simmons Mattress Crib 'n More Logo
1,122 people viewed this question
Top Simmons Mattress Baby Gear Experts
Stan Skaggs
Stan Skaggs
Glen Weitzdoerfer
Tom Chichester
Are you a Simmons Mattress Baby Gear Expert? Answer questions, earn points and help others
