Question about Whirlpool GU2400XTP Built-in Dishwasher
Water not draining out of dishwasher
Water fills bottom of dishwasher overnight. I disconnected the drain hose, and it was full the next day. When I disconnected the water hose, there was no water in the bottom the next day.
    Master:
  • 416 Answers
It can be clogged air lock or clogged hose somewhere next to the sink.
Good Luck
Posted on Jan 18, 2009
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Dishwasher filling with water when not in use.
you need to replace the fill valve located on the left side behind the kick plates located at the bottom of machine. But you can test this by turning off valve located under the sink.
However if the disposal is clogged its possible that water is back filling as it usaully drains through the disposal. Also make sure that the drain hose has'nt fallen below p-trap of sink.
Jul 12, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water wont drain out of bottom of tub. The dishwasher works fine, it just wont drain the dirty water out. If I restart it to wash again, the dishes are washed in the dirty water.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jul 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Apr 14, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
MDB5600AWQ Will not drain
yep first disconnect the drain hose from the sink drain then get a mop bucket shut the door and start the dishwasher the fist thing a dishwasher does when you start it is drain before it fills hold the bucket under the sink and loop the hose up and like its connected and see if it drains if it does then check the sink connection for an obstruction if not pull the bottom kickplate you will find a tech sheet there that will be help full also look to the left hand side and you will see a small drain pump make sure the wires are hooked up you should hear the pump running when you first start the dishwasher before it fills after the pump stops running open the door and turn it off if the pump is running and no or very little water is coming out of the hose then you will have to remove the pump and check to see if something is jamming the impeller reply to me if you need to and we will take it from there ok
Mar 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Whirlpool GU2400XTP Built-in Dishwasher Logo
90 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
