Question about KEF Audio Cresta 2 Speaker
How do I test an 8-0hm speaker or horn with a digital multimeter? Help!
Hate to admit it but I'm a musician with absolutely no knowledge of how to test a good or bad speaker, other than running a 9v battery to the terminals for + and - determinations and seeing if the speaker goes in or goes out. I have a sperry dm-350a digital multimeter...would like to test a speaker and horn to see if they work, before I buy. How do I do it? Does blk. lead plug into com and red into Ohm? What should the setting on the ohm meter be for an 8-ohm speaker? What are the parameters for an 8-ohm speaker..that is, what are the minimums and maximums that the meter should read to determine if the speaker is good or is bad. Thanks for your help. Dave
What? You can take a friggin multimeter, stick it across the terminals and if it does nott give you any resistance back you fryed the voice coil. If you get 0 ohms it means you fired the voice coil. If you get 4, 8, 16 ohms then your good to go.
Posted on Sep 29, 2008
  • cmagos Oct 21, 2010
    But as Zeusfaber said....that still doesn't mean the speaker sounds good......there are other variables.....and he also said you can test with the meter...so don't get so upset....it was great advice listening is the BEST way and if the person selling can't accomidate run away
  • DAVID MAKAN
    DAVID MAKAN Aug 01, 2014
    WITH A 8 OHM SPEAKER IT SHOULD READ BETWEEN 5 TO 7 OHMS
  • 247 Answers
To be honest, a multimeter isn't going to tell you a whole lot more about the state of the speaker than your game with the 9V battery (although it's less likely to damage a small speaker). The main reason for this is that speakers are designed to have quite different ac and dc resistances (technically, the ac version is called "impedance" - though both are measured in ohms). The multimeter measures the (dc) resistance - which varies depending on the size and quality of the speaker, while the 8 ohm spec applies to the (ac) impedance. Remember also that a lot of the bad things that can happen to a speaker are mechanical, and won't show up on an electrical test. The only really reliable way to test a speaker is to insist on hearing music - preferably something with a broad frequency range - played through it at a range of volumes before you buy. If the vendor is reluctant to oblige, then you can probably guess what state the thing is in. (If you still want to try the ohm meter out, then one lead in "common", the other in "ohm" is a good start (doesn't make a lot of difference which goes where). With an analog meter, switch between the ohms ranges until you find one that puts the needle near the middle of the dial (remember, the ohms scale reads backwards). With a digital meter, use the lowest range that doesn't give you an error. You aren't going to damage either speaker or meter in any of the ranges.)
Posted on Jun 22, 2007
    Problem Solver:
  • 3 Answers
Zeusfaber partially answered your question and there is not a set measurement for measuring speaker resistance. If the speakers have a crossover network it will also affect measurements at connections. The impedance of speakers is an in use AC measurement with an applied signal. Impedance measurements requires the use of an impedance meter versus an ohm meter. Sound signals are generated from an amp in an variable AC wave form so they are measured in AC impedance. This variable AC wave form is what causes the speaker magnets to vibrate back and forth to produce sound. When using an ohm meter on a speaker it will only measure the resistance of the windings on the speaker core and these windings are of different length according to manufacture and speaker type, tweeter, woofer, midrange, wire size, magnet, etc. In short, measuring with ohm meter is not reliable and it's best to listen to with high freq and low bass freq, then inspect cones and speaker mounting for damage, movement or looseness. Physical damage to speakers cannot be measured by any meter so in use is the best test. Using a 9v dc battery on ac speakers and crossovers could cause damage also unless it is a very high wattage speaker, which most are not. Speaker signals in home and car speakers are usually in milivolts, which is a very low voltage, so be very cautious. I'm no electrical engineer but over the years this is what I've learned about speaker science and not getting burned on used speakers.
Posted on Feb 25, 2008
  • burn your speaker with lighter
  • throw your speaker to your neighbor
  • bring your speaker to the nearest service station and say eat this you *********
  • i hope this 21th century solution will help you
Posted on Apr 23, 2010
    New Friend:
TEST IT WITH A DIGITAL MULTIMETER THE SPEAKER ITSELF NOT WITH THE CROSSOVER IT SHOULD READ AROUND 6 OHMS. SPEAKERS WILL ONLY READ ABOUT 75 PERCENT OF THERE REAL IMPEDANCE ON A MULTIMETER
Posted on Aug 01, 2014
Audio problems. The rear speakers sometimes work, sometimes don't and the driver side door never works. I don't know if it is the wiring or speakers.
A good way to test speakers / wiring is to use a 9v battery. Unplug leads from the deck and jumper the 9v + and - to the speaker wires and see/ listen for the speaker cone to move. With this simple trick you can trace problems pretty quickly
Aug 14, 2016 | Cars & Trucks
Where is the amp for the sound system on a 1998 jeep cherokee located
why not go to speaker and OHM it direct.
or take it out and test it on any radio.
or connect a 9v battery(smoke) hear it click load, = good
unplugged sure. in each case.
the fsm is free.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Sep 01, 2015 | Jeep Cars & Trucks
Home subwoofer no sound
always 1 speaker per amp output!!! and between red and black only. You can send any signal into a subwoofer. Hi frequencies will be quiet but it's safe. switch a normal speaker for the sub and listen, you should hear a muffled sound. Look for the sub output on the amp... do you need to switch on the sub manually somewhere?
Sep 02, 2014 | Boston Acoustics Audio Players & Recorders
Car Audio
Swap wires between speakers and to make sure it is not the amp, the head unit or wiring. If the right speaker still doesn't work touch a 9v battery to the speaker terminals for a second to verify if the speaker is good or bad (a pop the speaker is working nothing the speaker is bad)replace. Otherwise check the wiring between the amp and the head unit. If all the wiring is good you may have a bad channel in your amp(bad internal connection or bad component(s)) or last there could be a bad channel output on your head unit. If that is your only right speaker and you don't have one in the door and you use an ipod as a source check the cord!
Jul 04, 2013 | Car Audio & Video
Mixer will only play through one speaker; this is same with organ, microphone and ipod connected. Swopping jacks results in speakers swopping proving that woring is good, but mixer will not play both...
Sounds to me like either an open wire or a blown speaker. I would highly recommend not operating it until it is fixed before you blow the amp. Tapping a 9V battery across the speaker (disconnected from amp) will cause a noise in the speaker, if not it is a broken wire or bad speaker. Good Luck
Jun 06, 2013 | Behringer XENYX X1832 USB Mixer
Battery test good. alternator test good. But
YOU COULD HAVE BAD POSITIVE BATTERY CABLE OR LOOSE OR DAMAGED FIELD WIRE GOING TO ALTERNATOR.
Jul 13, 2010 | 2001 Chevrolet Suburban
My inside highs cut out . want causes this?
Alot of amps and speaker crossover have protection circuits built into them so when you turn up the music to much it's there so you don't blow your speakers. Try turning down the gain on the amp if that does'nt work check your speaker wiring for out of phase meaning
+ - wires are backwards. To test them use a 9v Battery touch the speaker wire to the + - terminals on the battery if the speaker pops out it's inphase and good if it pops in it is out of phase reverse wires and if all that checks out get a stonger amp.
Apr 20, 2010 | Sony Car Audio & Video
2003 avalanche rear passenger speaker not working
get a small square duracell 9v and connect positive from speaker to positive of batterie and negative from speaket to negative of batterie it should make a poping noise
Mar 11, 2009 | Car Audio & Video
I have a Kidde model 0976 9V battery powered ionization smoke alarm. It chirps roughly every 45 seconds. I have changed the battery but did not cure the problem. Any ideas as to what the problem...
hi - I think I just fixed the problem for mine. I had the exact same problem. Literally just got back from the store with 2 brand new 9v batteries with an exp. date of 2013 (I made absolute certain they would be years away from expiring). I installed them, and I'll be damned if they didn't start chirping again. As I read the instructions one more time, it occurred to me that it was in hush mode. I pressed the "Push and and Hold To Test" button for about 2 seconds - not long enough to set it off. It hasn't chirped since, and it's been nearly an hour. Try that and see what happens. Good luck!
Sep 08, 2008 | Computers & Internet
Testing with 9v battery
use the speaker wire postive wire and negative wire, touch the 9V battery + and - , you can hear the noise, then you will find out which speaker is. try it. I had a car stero company.
Jun 24, 2008 | Car Audio & Video
KEF Audio Cresta 2 Speaker Logo
27,358 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
