Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Blowing bulbs on polaris xlt
93' polaris xlt keeps blowing headlights. tail light works fine. just the headlight blows. thinking voltage regulator
My 2005 matrix keeps blowing 15amp rear running light fuse every time light get turned on all other lights work fine.whats causing this?
fuses blow because of dead shorts or excess current draw
to blow a 15 amp fuse indicates a dead short
by disconnecting the rear lights , the problem is in something else you have replaced
could be a problem in the head light wiring
Feb 05, 2016 | 2005 Toyota Matrix XR
Why does my Atv Polaris sportsman 90 keep blowing headlights???
Lousy bulbs or poor voltage regulation (too high voltage will burn out incandescent lamps especially when you factor in all the bumps and vibrations ). Maybe you can special bulbs designed to withstand the conditions presented by your ATV.
Sep 08, 2015 | ATVs
Yamaha v star
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re Grrr Headlight keeps blowing fuses Road Star Forum Yamaha Road Star
Keep blowing headlight bulbs
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
May 13, 2014 | Yamaha V Star 1100 Classic Motorcycles
Check the amps that are being drawn by the headlights. Compare that with what the bulb should be drawing using:
amps= watts / volts
I am going to guess its higher but not to the point of blowing the fuse for your lights. I would then start checking grounds.
Or, you used halogen bulbs and you touched the glass. I doubt they would both fail at the same time from that.
May 11, 2013 | 1997 Toyota 4Runner
Wr450 headlight keeps blowing
Hi, Nathan if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.thumpertalk.com/topic/1193575-2007-wr450f-keeps-blowing-headlight-bulbs
headlight buld keeps blowing
Yamaha WR450F Owner Service Manual
YAMAHA WR450F Owner Manual
Jan 24, 2013 | 2008 Yamaha WR450F
My wifes 92 883 keeps blowing headlights. First the low beam then the hi-beam. Is it the headlight relay shooting too many amps to the light?
Check the headlight lens for moisture in them, that blows bulbs. Do you touch the bulbs with your fingers when installing them? Don't do that, that blows bulbs. And no to many amps is not possible, but to many volts,is poss, have the charging system tested by a local Autozone or O'reilly auto parts, its is free, it could be to much voltage due to a alternator issue or wiring problems. Please rate my help for fixya..
Aug 30, 2012 | Cars & Trucks
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
Anyone know about 1996 polaris sportsman 400 - none of the lights are working - headlights, tail lights, not even the neutral light or reverse lights work - have looked for for broken wires and can not...
I also have a 96 Sportsman 400...local dealer told me if these bikes are operated with a low\bad battery the electrical system is designed such that the light bulbs will blow. I and a bad battery and non of my lights worked when I got the bike started. So, I replaced the battery and headlight bulbs and they now work. I would recommend replacing your battery if it's questionable and then your bulbs...worked for me!
Nov 08, 2010 | Polaris ATV
1995 polaris 425 magnum 4x4 blows the tail and headlight bulbs. replaced regulator..still does it. battery shot. does it have to have a good battery hooked up in order to work properly?
i had a polaris scrambler three wheeler and it would blows bulbs also, it had a junk battery in it, never thought anything of it, read up on it and if the battery has a short in it, it will blows the bulbs, replaced the battery and didnt have any more problems blowing bulbs
Oct 04, 2009 | Polaris ATV
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
135 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
